TV repair discussion thread (consolidated)
PA3131T
Hi freakinclown,
Ive this 47LG60FR 6 years old.
No picture or sound for HDMI source when I turn on StarHub Hub Station. Tested 2 HDMI cable, same, just a blank blue screen. Test with my Bluray player, same thing. Tested using AV line, ok. Meaning hub station is ok.
Tested both the set-top box n bluray player on another TV, both working fine.
But a very funny thing is that when I use my TV box, everything ok. Picture n sound working...
Hope to hear from u soon... TIA.
freakinclown
Hi freakinclown,
Hello!
Did you test your set top box and blu ray player on the other tv using hdmi also?
And..by saying your tv box, are you referring to the usual tv channels that you watch either via analogue or digital signals?
PA3131T
Hello!
Hi,
yup yup.. set top box n bluray tested with the other tv using hdmi n both working...
the tv box i watch tested on live streaming n vod using hdmi all along, meaning i suppose is digital signal as per ur question....
freakinclown
Hi,
So for the tv box, you connect it to the tv via hdmi as well, and it works?
PA3131T
yup, exactly... thx for the fast reply...
hope to find out the problem or at least cfm if my tv gone le...
then can work something out from there...
freakinclown
That's actually very weird. In this case, we'll need to do a check on the tv before we can tell what's wrong with it..
PA3131T
Ya mann... really something that I nv hear of n Im experiencing it now...
Ok, will PM to discuss on it if we gonna proceed...
Thx for all the reply thus far... Cheers...
I Not Stupid Idiot
i have a 42inch LG, model 42LG55FR-TE.
Screen just turns white when i power the TV on. Cannot turn it off by physical button either, only can use main power switch. Worth it/Possible to fix?
freakinclown
Hello there! For your tv, it's quite hard to tell exactly what's wrong without checking it, but there's a possibility that it's a problem with the motherboard. As for whether it's worth repairing, it depends on several factors such as the cost of your tv, how old it is, how much you like it etc. I'll send you a pm regarding the cost of repair.
ashonthenet
hi freakinclown,
i have a 42pfl5609/98 philips tv.
when i turn wall power on, as normal the red light will be on too.
when i use remote press on, there will be the normal crackling sound that philips tv make.
thing is there is no display and no sound. but whatever buttons i press on the remote will make the lights blink as per normal. this means part of tv still working.
any advice on this, such as how to hard reset the tv?
can pm me also if repair will be how much?
thanks,
Ashraf
orion888
LG TV problem
Hi freakinclown
My LGTV 42LV3730 suddenly cannot turn on
- either use remote or button on TV unit, the red LED turns on but will blink on/off slowly, screen remains black
- please PM me on how much to repair and how to contact you if needed
PentiumPC
My 42" LG TV won't turn on intermittently, some time it goes into a clicking loop.
Please pm estimated repair cost. Thanks.
VigilanteX
hi freakinclown. I have an old 2010 model panasonic led tv model no. THL32D25S
The tv's analog tuner is not working. everything is dark when i switch to analog and no amount of tuning works. However, everything is fine when I switch to dvb-t. I am able to get the available channels. connection to hdmi works too. i can get the picture very clearly. Is it possible to repair it? Or does a certain part have to be replaced? would it be expensive and worth it? Or should I sell it to second hand dealers? what would be the price for repairing or replacing a certain part. can you give a rough estimate?
thank you.
freakinclown
thank you.
Hello!
It should be a problem with the tuner.If it's in a condition where it's repairable, the repair cost will be cheaper. If it's not repairable, and the entire board needs replacement, then it would get very expensive and I wouldn't recommend you to repair it.
We will only know whether it's repairable after my dad does a check on the tv. If you need more info on the exact cost, do pm me. Hope this helps!
eguy899
Hi freakinclown,
I have a sharp lcd TV model no. LC42G7M.
The images are faded, lacking in contrast when the TV is switched on. No amount of adjusting the brightness/contrast helped. Is it possible to repair? Pls give an estimate if it is still repairable. Thanks.
freakinclown
Hi freakinclown,
Hello!
I've just checked with my dad on your issue. He says that for your case, he can't tell the cause of the problem without checking I out your tv. Therefore, I am unable to tell you if it's repairable or not. Do pm me if you need more info on this.
Hope this helps!
