shawniiex
- Mar 29, 2011
If i root just to unlock and never flash any rom, can i still get OTA update?![]()
Yes
10 char.
I love CM12 ROM. After so long never use CyanogenMod ROM, I am back now.
- Awesome Themes, customize everywhere.
- LED Notification light working perfectly! no need light flow. (why Google/Moto you disable it)
Unless you root and install stick mount, you cannot write on exFat or NTFS.
Only can do so on the old and clunky Fat32![]()
Don't update nighties 1802...for CM12
Just caused havoc to my Nexus9 and heard that some Nexus6 also broken.
now which site can get XT1100 cheaper? And is the XT1100 turbo charger the UK 3 pin? please advise.
cheapest:
- lazada for att set which is unlocked by seller - kile. proven by few users here.
- amazon eu/fr for xt1100 set.
Yes, UK is 3 Pin charger. usable in SG.
yes, based on the user brought from himoh! so if we purchase from kile he will take care of the unlocking for us la, then no worries about buying from him ald siah
Sent from OnePlus A0001 using GAGT
