The Nexus 6, the Lexus of the Precious Nexus?
porcu
U will be missing out a lot if you don't root and install custom ROMs :)
porcu
Can try CyanogenMod12. Can double tap to wake, light notification, ...
jingwei
I love CM12 ROM. After so long never use CyanogenMod ROM, I am back now.
  • Awesome Themes, customize everywhere.
  • LED Notification light working perfectly! no need light flow. (why Google/Moto you disable it)
What themes are shown here? They look really good.
kennyg1969
Unless you root and install stick mount, you cannot write on exFat or NTFS.
Only can do so on the old and clunky Fat32 :(
Yeah.. You are right. My fat32 stick is readable via ES file explorer whereas my sandisk otg stick is unreadable.
shawniiex
Happy New Year to all!
As part of the festivities!
I'm selling my Nexus 6 Cases at $12 each instead of the usual $16.50
My cases come in Black, Blue, Gray or Red.
Might be my final batch for Diztronic cases as army commitments are becoming more and more!
For any enquiries you may contact me at 92221335.
Alternatively you may just place your orders at my order form!
porcu
Don't update nighties 1802...for CM12
Just caused havoc to my Nexus9 and heard that some Nexus6 also broken.
ipple
now which site can get XT1100 cheaper? And is the XT1100 turbo charger the UK 3 pin? please advise.
garychengjw
cheapest:
- lazada for att set which is unlocked by seller - kile. proven by few users here.
- amazon eu/fr for xt1100 set.
Yes, UK is 3 Pin charger. usable in SG.
NaZzZzZ
anyone received their nexus 6 from amazon.com yet? mine's nearing the expected delivery date and still no news. also, any issues with the turbo charger?
thanks in advance guys
