New Asus firmware is out
ASUSTeK Computer Inc. -Support- Drivers and Download RT-AC87U
Let's see what they fixed
Let the complaints begin .......
Anyone tried? 5Ghz still drop??
It's the one that was for Japan only.New Asus firmware is out
Waiting for Asus@sg to feedback if this is the version he is referring to. Or is there another one on the way...5ghz will still face problems so long the quantenna driver is the same.
Thats why initially i challenged asus@sg why cannot update to this version albeit indicated for japan only. Asus@sg did not respond to this.
Now merely they update the change log. Simi fixed nat loopback, its still happening leh.
Simi update signature version to 1.030? I still at 1.010 despite a reset and set up the router as new. Rebooted afterwards, signature version still the same. Not a big concern to me, but merely lowers the credibility of asus branding nia..
Ok to be fair, other quantenna powered routers are still facing this disconnection problem.. My only chance is to wait for my android lollipop update in hope for this.
This router is hopeless..I am on viewqwest 600mbps and sitting beside my router:
I connect to 2.5ghz and using my speed test, my speed test only 30mbps
I connect to 5ghz and using speed test, my speed test is only 200mbps.
Wonder whether will fair better with Asus 68U
I am trying now!!
1. MASSIVE PS4 LAG with " Nat Acceleration" ON MASSIVE: OFF it seems good!!
2. DNLA media server would not work: FIX : turn it off and on and apply!!!
3. TO BE continued........
IOS or wifi loss problems usually only show up in 24 to 48 hours, well see..
NOW with that said and the fixes above for the only 2 problems I see !!SO FAR!! I see no other problems YET
EDIT1: I still get this, no big deal, but to whom want to know
Feb 25 17:31:43 kernel: br0: received packet on eth1 with own address as source address
Feb 25 17:34:39 kernel: br0: received packet on eth1 with own address as source address
WOW!!
3 hours later and lost wifi !!!!!!!!!JUNK!!!!!!! had to turn off and on wifi on iphone, wow!!
back to dd-wrt right now!!
And ASUS@SG goes quiet again…
I don't mind downgrading to RT-AC68U + USB-AC56...Maybe he preparing sets of AC3200 and exchange for us.... No worry..
If you are having issue with the older 3.0.0.4.378.XXXX, there's no need to try this one. Same shits with happen.you guys tried Asus RT-AC87U Firmware version 3.0.0.4.378.4376?
