Sony Xperia Z3 Tablet Compact
lekhte
Strange, thought the official cover will have this feature.
Is the flap held close by magnetic?
The flip to wake feature it's actually wake the screen by magnectic.
If you don't want this feature, got to search for non magnectic case specifically
I think most non official case also have magnectic feature. So might take some time to search
sg_scouser
would like to check hows the battery life of u guys..mine seems to drop 3-5% overnite on standby..is it normal?
Albedo
Why not? But you have to use either bluetooth headset or wired headphone or speaker phone, dont expect to be able to hold up the tablet beside your ear like a decent handphone, lol.
actually i am using this as a phone, holding it against my ear.
the speaker volume i set to min during phonecall...
of cos, using a BT headset or plug in earphones is still better....
jazzman80
mine the most 1%. on top of all the functions are off, Google play services might be the culprit for battery draining. for me, I restore back to the original version.
if you are not using Google now,go to your app drawer > Google settings. go through all and probably the last one 'security', I unchecked all before I restore back the firmware of Google play services. hope it helps.
jazzman80
apps > downloaded > Google play services > uninstall updates > running apps > Google play services (should be a few running) > click all and see, for me, I stop those location related ones, and Google analytics service
sG_KYo
last night 1% only. with stamina mode on wifi and data turned off
3-5% is normal. especially if u have emails pushing in the background etc. My set usually last me 1.5 days with streaming for 2hrs to TV - usually the latest cartoons and US Sitcoms that i have just erm ... ahem ahem ...
Albedo
can anyone tell me what is the dock that I should be getting?
Is it the one used by Z2 tablet? DK-39/40?
Thanks!
sG_KYo
Thanks!
actually, get this ...
BSC10-Bluetooth-Speaker-with-Magnetic-Charging-Pad-hero-black-1240x840-48a361210701c57bd08717aea2b06fae.jpg
U won't regret getting it. Quality sound and easy to swap around to charge for all Sony devices.
Albedo
thats nice but i am just looking for a cheap charging dock.
