[Maylyn's Review] ASUS RT-AC66U Dark Knight Rises
hazzeline
Help!
Hello,
I recently upgraded to Singtel 300 mbps and i am new to routers. However i cannot achieve 300mbps upload and download speed with my ac66u. Kindly advise what settings must i configure to achieve optimal speed.
Also i realised when i used ac at 5GHZ for both client and router. The output the router can achieve is only 90mbps which is far from my subscription speed. Is this suppose to happen?
Thanks!
shadow84
Hello,
Thanks!
What wireless adaptor u r using? How many walls from router to your pc?
Getting 90mbps from a 300mbps plan via wireless considered not bad le...
new64
Recommendation how to connect Singtel fibre 200 with mioTV
Hi All,
any recommendation to connect singtel fibre 200mbps with mioTV using RT-AC66U?
should i use the default Aztech FG7003 connect to mioTV STB and pull
one network cable into RT-AC66U ?
this will keep mioTV working
or should i remove Aztech FG7003
and try to setup vlan for mioTV and use it ?
what is the recommended connection ?
thanks!
tanyj82
new64
You can connected direcly, plug the cable to wan and login to ac66u
LAN-> IPTV
Select Singtel others.
Then connect your mio tv to port 4
Phrajile
Hi all
Just bought the AC66U and is currently paired into my Viewqwest fibre (VQ modem is currently in Bridge-mode providing fibre to the AC66U)
I have a question:
(updated to latest firmware, btw)
With both 2.4GHz and 5GHz enabled, I find that my PS4 completely disconnects from the wifi whenever my Asus T100 Transformer connects to the wifi. Disabling the wifi on the T100 reconnects my PS4.
Turning off 5GHz, the connection works.
TLDR:
2.4 + 5GHz:
T100 + PS4 - PS4 disconnects from Wifi
Mobile + PS4 - both works fine
2.4GHz:
All works fine.
Any suggestions? PS4 is given static IP + placed in DMZ. Changing the 5GHz SSID doesn't work.
eyz
Does anyone know why is my 2.4Ghz connection is faster than my 5Ghz?
The 2.4Ghz d/u speed is 90/75 and 5Ghz d/u speed is 68/127.
It's also weird that the upload speed of the 5Ghz connection is almost twice as fast as the download speed.
leowweiqi
2.4ghz is better for longer range compared to 5ghz.likely the range affect ur 5ghz speed
eyz
but i was sitting around 2.5 in front of my router.
i tried merlin FW as well, not much difference..
ASUS@SG
Suspended
Dear eyz,
Which device are you using?
Please provide us 5Ghz settings om your router.
Best regard,
JK
ho_kailiang
Firmware Version:3.0.0.4.374_4561
May i know which is the most stable firmware for AC66U?
Currently facing internet connection issue for this router.
steven168z
you can try ASUSWRT-MERLIN
A CUSTOM FIRMWARE FOR ASUS ROUTERS
Visit http://asuswrt.lostrealm.ca/download for the latest version.
i am using ASUSWRT-MERLIN 378.51 on AC66U.
For general support question, please use the public Support Forum hosted at SmallNetBuilder.
http://www.snbforums.com/forums/asuswrt-merlin.42/
orange_20
hi guys. I just got this router last night but having some problems setting it up.
primarily I cannot access the router's homepage at 192.168.1.1
last night initially I could and I updated the firmware to the latest on Asus website. but this morning totally no wireless signal coming out from the router.
tried to access the router homepage and couldn't again. since then I've tried almost everything including restoring the firmware using Firmware Rescue but still can't work.
would appreciate any form of guidance or help here. thank you.
j_t_fusion
hard reset router.
then connect via LAN cable to router to update firmware again. and then reconfigure everything again.
orange_20
hard reset router.
I've tried that already. after firmware reflashed, it works for a while and then when powered off and on again, it doesn't work again.
can see that the router keeps rebooting itself.
orange_20
So long it's a local set, you can still RMA base on manufacturing date. No harm to give it a try.
icic. where is the RMA centre for asus routers?
then try flashing to a third party firmware like dd-wrt or openwrt.
if after flash still have problem then high chance is hardware problem.
I tried the Merlin FW. still stuck in reboot loop. thanks a lot for your advice.
renfred89
You cannot RMA with a 3rd party firmware I think,try to install the stock firmware if you can.
The service centre for Asus routers is at kallang. You might want to refer to avertek website..
