Merlin 370.51 Beta is out .........
In AP mode ... more menu added.... and log improved..... GUI more easy to read.
378.51 Beta 1 (28-Feb-2015)
- IMPORTANT: The RT-N16 is no longer officially supported. The increased
number of separate router platforms is becoming too much of
a burden for one single developer, as some features must be
implemented 2-3 separate times for different architectures.
The RT-N16 support will remain in the source code, so other
developers can still compile their own builds, and possibly
take over for supporting this older platform. However, no new
features will be implemented, and it will no longer get
tested. I still welcome external contributions if
someone else wants to take care of testing and providing
fixes to new issues.
- NEW: Added support for the RT-AC3200.
- NEW: ARM support for Entware, using Zyxmon's Qnapware repository.
- NEW: Re-designed Wireless Log page displaying connected wireless
clients. The new page uses Ajax to automatically update
itself at a user-selected frequency, for near realtime
monitoring of your connected wifi clients.
- NEW: NAT loopback can now be chosen between Disable, Asus's original,
and Merlin's own (based on Phuzi0n's original DD-WRT design). The
option can be found on the Firewall page.
- CHANGED: Reverted RT-AC66U driver to previous version as some users
were experiencing stability issues with the 3754 version.
- CHANGED: Updated p910nd to 0.97 to resolve incomplete print jobs
(patch by stsichler)
- CHANGED: Updated Samba to 3.6.25
- CHANGED: The Entware setup scripts will now backup any existing
installation rather than remove it (patch by TeHashX)
- CHANGED: Re-implemented our original NAT loopback code, with attempts
at reconfiguring it whenever the DPI engine is restarted.
This is still experimental, as most of the DPI engine is
closed source, so unsure if the loopback gets re-enabled
in every regular DPI restart scenarios.
- CHANGED: Disabled the offline default error page. Clear your offline
content in your browser to fully get rid of it.
- CHANGED: Removed security warnings if FTP/Samba are configured to
allow unauthenticated users.
- FIXED: Issues when connecting with Russian ISPs relying on DHCP+VPN
(such as Beeline)
- FIXED: When enabling WAN access to webui, the router would always
forward both http and https ports regardless of if either of
these were disabled.
- FIXED: Shared printers over LPRng would sometime fail to
completely print the last page (patch by stsichler)
- FIXED: CVE-2015-0240 security issue in Samba 3.5.8 (used by
AiCloud). The main Samba daemon was patched by the
update to 3.6.25.
