[Official] Aztech FG7008GR(AC) AC2400 MU-MIMO Gigabit Router
renfred89
There are a few aztech 7008 router threads here and there, and i thought we could have a consolidated thread solely for Aztech FG7008GR(AC) model.
This thread will be used for discussion on the usage, troubleshooting, enquiries on how to set up and such. For fibre broadband performance, kindly refer to The Next Generation Broadband Network (NGBN) Forum
AZTECH FG7008GR(AC) AC2400 MU-MIMO Gigabit Router
Key features:
Beamforming Technology
Concurrent Dual Band Wireless Connectivity: Wireless-AC data transfer rate up to 600Mbps (2.4GHz) and 1800Mbps (5GHz) frequency band
2 x USB 3.0 Ports to enjoy a faster method of sharing a connected storage’s files throughout the network
Multi-User MIMO
Wi-Fi Protected Setup (WPS)
Easy Setup and Installation
Aztech FG7008GR(AC) Specifications Singapore
Latest Firmware info:
{Updated as of 16th March 2015}
Latest firmware downloadable here
Firmware Version: 322.6s.2-011
Updated: 5th April 2015.
Suitable for Singtel 200/300/500mbps Fibre Home Bundle, or Fibre Entertainment Bundle+.
As this router supports vlan tagging built-in, users just need to plug and play this router. No additional settings required. As easy as using the singtel's given residential gateway (modem).
I have test this router for use with Singtel's 200mbps. Broadband performance is better than the previous given router, and works well with singtel tv. no pixelation or poor viewing experience.
trichard
I tried this unit for 1 day and after that top up to AC87U.
I conclude that internal antenna is a No No No.
WWE_Fan
I paired this with Linksys RE6500HG for about two weeks. Impressive for ease of use and that the autoconfig with my Fibre with TV plan works without issues. Unfortunately guest network is missing. Hopefully in next software update?
renfred89
Guest network is still available, however only restricted to 2.4Ghz.
You may want to access the advanced portal and look for it under 2.4Ghz basic settings. its at the bottom..
renfred89
Pls change year to 2015
thanks, already amended! xP
No changelog
aztech did not release the changelog, however in this firmware, it carries the latest quantenna driver to address the 5Ghz disconnection when apple devices are connected.
This driver was originally in the 008 version and was not released to public unless upon request. The current 009 version requires a hard reset if there are problems relating to stability issues.
I did a hard reset anyway.
WWE_Fan
How should the firmware be updated to the router? If it saved in a thumbdrive and plugged to the router, can the update be triggered from admin portal?
renfred89
You need to download it to your computer and then upload the firmware through the webUI.
Using usb directly on the router itself doesn't work.
renfred89
Official firmware update ending with 011 is now live on support site. Refer to #1 for link!
This firmware update is to address wifi issues on 5Ghz with mac machine..
kero89
Singtel or Aztech based GUI?
Support wireless AP mode? :D
Feel like hooting it at $159 during recon.
WWE_Fan
Under Advanced settings, there Bridge mode.
Btw, anyone knows, recently on iPad when accessing the admin portal using google app, some parts of the advanced menu settings are not displayed.
When I launched using Safari, I can access them.
Something to do with apple's latest update?
logicet
After i updated to 011, my 5 Ghz is bricked. Using mac to update btw.
Anyone face similar issues? Reset doesn't work as well. Still able to use 2.4 after resetting though.
renfred89
what do you mean by bricked?
thiamhui
Try change the 5GHz channel to a lower number (2 digits)…
