danxiaogui86
Dear all,
IT Show price
http://deluxeforums.hardwarezone.co...intelligent-wireless-your-devies-4996391.html
Best regard,
JK
can trade in bo.. hahaha~
thiamhui
ASUS RT-AC87U Firmware version 3.0.0.4.378.4608 (https://www.asus.com/Networking/RTAC87U/HelpDesk_Download/)
- Release note -
Bug fixes
- Fixed AP mode connection issue.
- Fixed guest network disappearing issue.
- Fixed rebooted issue when WAN disconnected and reconnected.
- Fixed traffic monitor GUI issue.
Security related
- Upgrade OpenSSL library to 1.0.0q
- Fixed CVE-201301813
- Fixed the XSS vulnerability on page Main_Analysis_Content.asp
AiProtection fixes
- Fixed router reboot issue when disabled AiProtection
- Fixed kernel panic when wan reconnected
- Modified web history strings
- Updated signature to 1.030
- Optimize memory usage
Bug fixes
- Fixed IE9 compatibility issue
- Fixed NAT loopback issue
- Fixed abnormal SSH system log
- Fixed network map UI issues.
- Improved UDP performance
Other
- Added Movistar profile in IPTV setting page
3.0.0.4.378_4376 has been removed.
renfred89
- Release note -
Bug fixes
Security related
AiProtection fixes
Bug fixes
Other
This version has been stable, in my opinion. Users should attempt this firmware if u r using 3885 and earlier.
I dunno why, it does not appear in windows 8.1 but windows 8. You guys might want to take note..
oric1
have leh, Win 8.1 (32 & 64 bit)
maylyn
On mobile i still see 4376 as latest. Bit nvm, it could be just slow in updating.. :)
It will need to take some time to propagate for the various OS.
Alternatively you can choose the OS-Others to see the latest update, it's usually being updated the fastest.
lawkoh
Still see lag on my IP cameras connected by lan, using 5Ghz as my connection access viewing locally.
Think that 5ghz is still unstable.
trichard
Oh ... Can post your link so that we can help test for you ?? :D
diubum
super slow speed
hi, i'm on singtel 1gbps but i getting ridiculously slow speed on this router on lan connection - 5mbps! wireless on iphone is around 50mbps. sometimes my pc cant even detect the lan connection at all. i installed the latest firmware but still same problem. Last few weeks no problem, could get speeds like 950mbps. is it a hardware problem?
renfred89
Try plugging out and switch to another lan pprt of ac87u.. Then test again..
