What The Flex can the LG G Flex2 do?
fireduke86
A good heat source.. i tot they would use samsung soc...
LG being a direct competitor, I am not sure Samsung would be agreeable to a sale of its Exynos~ :o Then again, Samsung did manufacture Apple's.... :o
Gaiason
really is WTF "What The Flex"... the LG G Flex2 really can tahan being sit by fatty bom bom....:(:(
mocax
heavy people sit on chair, the chair also will give way... let alone a phone.... :(
Gaiason
means the chair cmi loh....the LG G Flex2 ish solidly build....wun bend or break on heavy load.....:(:(
slowpokie
but withstanding 25kg is still a good to have sturdy spec......
performance wise
is this phone a premium phone ???
fireduke86
Pai seh my ang moh no good
flagship means popular or premium....
i kmow samsung s series is flagship or popular
premium is note series.....
Flagship means "premium" and "premium" doesn't mean "popular". S series and Note series caters to different crowds but that is for another forum.
slowpokie
oh lolol ok...... but then hor.... does the phone come with the ultra fast charging tech ?
Charge 10 mins can use 4 hour is beary satki
mosmos
High Honorary Member
The LG Flex 2 gives an ergonomic hold on the phone which sits comfortably on the curve of the palm.
Its 5.5" 1080p screen, 2GB ram, 16gb rom, 3000mah battery non-removable, looks great but I wonder 16gb will be enough for normal use these days? The apps are getting bigger
mosmos
LG G Flex 2 has Android Lollipop 5.0 , POLED , OIS+ , Knock code, plus Qualcomm 810 snapdragon processor , it seems not the highest specs mobile phone in the market now.
fireduke86
I suppose with a MicroSD slot that support up to 128GB cards, it should be sufficient, especially since Lollipop comes with the ability to move apps to SD~ :o Then again, it's the 3GB ram that is enticing~ :o
Nakedtoes
The LG Flex 2 gives an ergonomic hold on the phone whicb sits comfortably on on's palm. With its 5.5" 1080p screen, 2GB ram, 16gb rom, nothing can stop in its way.
it supports 128gb microsd with a 3000mah battery
the LG G Flex 2 is also powered by the following technologies:
Android Lollipop
POLED
OIS+
Knock code
Qualcomm snapdragon processor
Nakedtoes
Actually not much different 2gb or 3gb...if the launcher implement correctly 1.5TB ram is more then enough
