What The Flex can the LG G Flex2 do?
mosmos
High Honorary Member
I suppose with a MicroSD slot that support up to 128GB cards, it should be sufficient, especially since Lollipop comes with the ability to move apps to SD~ :o Then again, it's the 3GB ram that is enticing~ :o
I faced a problem with my phone using kitkat when downloading and installing apps, the phone will check for internal memory first.
mosmos
The LG Flex 2 gives an ergonomic hold on the phone whicb sits comfortably on on's palm. With its 5.5" 1080p screen, 2GB ram, 16gb rom, nothing can stop in its way.
Not forgetting that it supports 128gb microsd, which should be the next big thing.
But i find it weird that there is a 2GB ram/16gb and 3GB ram/32gb model. Why cant they do both at 3gb ram, save the trouble....
Battery looks big at 3000mah.
the LG G Flex 2 is also powered by the following technologies:
Android Lollipop
POLED
OIS+
Knock code
Qualcomm snapdragon processor
Satki boh my post
Nowadays flagship phones got 3gb or 4gb ram, wonder 2gb ram still enough for these days resource intensive apps?
Nakedtoes
LG Flex 2 can withstand 25kg of weight.. But we sit down weight sure more...
mosmos
it supports 128gb microsd with a 3000mah battery
Android Lollipop
POLED
OIS+
Knock code
wonder how much does the performance if internal 128gb vs 128gb sd card
Nakedtoes
Our pigu sure weight 4x more :s22:
Not a problem actually.. cause the LG flex 2 can flex until straight... same as flex 1.. Should have ask a sweet lady in bikini to seat on the phone.... video more power... :D
gwzc_mk2
own the original flex and bought the flex2 for my wife. (basically she's using both the phones)
here's my take on the flex2
- the size is much friendlier for the hands
- full HD POLED screen. compared to the flex, flex2's screen have more contrast thus the photos and videos appears very rich and nice
- expandable sd card slot. its a feature lacking in the original flex
- smaller battery compared to original flex but the phone can last throughout the day without any issues.
- knock code. a great improvement from the "knock on" feature. now can launch apps using codes and less stress on the home button
- quick selfie mode. found out about this function while playing with the flex2. while in camera app, just swipe right to switch to front camera. no need to fiddle ard with on screen buttons to switch the camera around
- dual flash. makes the pictures taken with flash a lot more natural
- OIS
shadow84
There are 31 days till contest end. Everyday can get hw many points? I got 34 le....
Nakedtoes
The video also nv show the aftermatch.. maybe the full HD 5.5 inch screen Corning Gorilla Glass 3 got crack already?
Nakedtoes
highest i see is 43 points.... so 30++ days can reach... redeem a phone much better then 64 microsd previously
slowpokie
3000mah is about note power..... nowadays battery more impt for me..... speed wise i give up liao.... the network is either cmi or my data nt enough
Nakedtoes
the LG Flex 2 should be able to bear a load of at least 25kg! 3000mah battery is actually not bad consider only full hd 5.5" screen. powered by Qualcomm MSM8994 Snapdragon 810 Quad-core 1.5 GHz Cortex-A53 & Quad-core 2 GHz Cortex-A57 should not drawn so much power.
xiaowhois
nowadays battery life quite short life for smartphones but now portable powerbank so cheap battery life wont be an issue but just need to bring 1 powerbank along with LG G flex2
xiaowhois
the question is how many sets of LG G flex 2 are available for redemption?
