- Jun 20, 2007
Erm, how to get points man????
Last I check kasia selling lg g flex 2 for 780, don't think there's any other Snapdragon 810 device cheaper than that price.is the price list out ???
i'm more interested in the lg g flex 2 hashtag #whyedgehalfway
hmm, directed to samsung?![]()
Sent from my imaginary smartphone using GAGT
really???Just type this:
LG Flex 2 jin satki can take 25kg
A 5.5" 1080p screen, 2GB ram, 16gb ram and it supports 128gb microsd with a 3000mah battery!
LG G Flex 2 technologies:
Android Lollipop
POLED
OIS+
Knock code
Qualcomm snapdragon processor
LG G Flex 2 wan sui!
Now, gimme my points ~![]()
Any comments regarding thermal throttling issues that was mentioned by other reviewers previously?
I read previously that snapdragon 810 was creating a thermal nightmare for most devices.
https://plus.google.com/113781386215450614303/posts/YVf8PRQ6Sqg
I do hope that LG addresses this issue through kernel level optimisation.
I noticed that it's mentioned that the newly launched LG G Flex 2 supports mSD of up to 2TB, is it a unique feature of the LG G Flex 2 or can its competitor support up to 2TB as well?
Just type this:
Android Lollipop
POLED
OIS+
Knock code
780 seems ok..... but think the xiaomi note comming soon leh..... probably 150 cheaper..... also as good in terms of money
the 128gb memocard is not exactly a big plus...... now on 16gb phone also try to tahan
is the self healing back gimmick?
later tio infraction
see how long you can wait lo, local market xiaomi mainly pushing budget model
mi4 never even appear at all, they only sell mi3 toward its eol![]()
doubt so, plenty of test online with actually knifes onto the back of the g flex.
go outlet find demo set and use key try lo![]()
post #2
- the flex2 runs on Android Lollipop 5.01 with a Qualcomm snapdragon 810 processor.
the 810 does heat up upon usage but the heat is still bearable.
- did i mention that there is a curved tempered glass screen protector for this phone?and i thought curved screen protectors was not possible. but then, the phone already comes with gorrila glass with a special in-house treatment that makes it 20% stronger.
- a feature not loudly advertised is the self healing back cover from the original flex. it does heal the minor scratches but please do not take a penknife to scratch it.
- flex 2 comes with 403ppi on a 5.5 inch 1080p screen. imho, its a great improvement.
- the 23-degree arc makes answering the phone in a noisy environment easier cos the speakers and mic are in the proper place.
- when rested on a table, the curvature + back speakers bounce the music off the surface, making it sound louder. no worries about the speakers being too soft or missed calls.
- Q apps. there are a few useful Q apps from LG thats quite good for everyday use. Smart Notice shows u the notification cards on calendar events, weather information and other tasks. Dual Window allows u to run 2 apps on a split screen simultaneously. there is also GlanceView, which allow u to check the time, date and missed notification without waking up the phone. just simply swipe downwards from the top of the display at lock screen.
- the flex 2 comes with Bluetooth 4.1, NFC and two different storage options (16 and 32GB). It includes either 2 or 3GB of RAM depending on availability.
- it also comes with a 13-megapixel back camera with laser autofocus and OIS+, 8x digital zoom, panorama shooting, a gridline overlay to help compose pictures and four sizing options (ranging from 2,048x1,536- to 4,160x3,120-pixel resolution). It can record HD, full HD or ultra-HD 2160p video, as well as slow-motion at 120fps.
- the front camera is 2.1 MP and it comes with a "beauty meter" where u can soften up the selfie a bit without using additional app
- it supports local 4G LTE
- flex 2, while using the stock charger, is able to regain 50% charge in around 40 mins. pretty fast for a 3000mAh battery
- comes in red or gray. imho, just get the red.
