What The Flex can the LG G Flex2 do?
kurt111494
Yup. Its currently available in two colors. I do hope that more colors will be released like white or white gold. I like white color cause it looks classic and elegant :D
We can always a use handphone case with pattern that we like though..
Current colors..
Actually...even without white color, those 2 available colours already look damn sleek :D Sooo shiny and smooth and sexyyyyy O_O
This phone is really aesthetically appealing ^^
kurt111494
Wah, 23 degrees arc??? Didnt know that..
Some may complain that the curvature is just a gimmick, but it's actually pretty useful in terms of viewing angles and voice clarity during calls :D
I gotta say, the curved screen is much more attractive than our conventional flat screen phones >.<
_MaOMaO_
#whyedgehalfway
I wonder how far durable it is.... 25KG is a little too little eh? should put like say 60KG (a normal person's weight)...
But good to hear it won't bend like apple
25kg is definitely more than sufficient. Nobody would purposely put the phone in the back pocket and sit down :o
For me, I only put the phone in my side pocket. When I sit down with the phone in my side pocket, the pressure on the phone will not exceed 25kg
_MaOMaO_
Yup. Now the rage is all about curved screen. Like Curved Ultra HD TVs. Same thing.. Curved screen on mobile phone
kurt111494
Agreed. Sometimes I feel that phones having some flexibility is actually good. Coz for most guys we wear normal jeans already feel a bit tight (slim fit). I can't imagine skinny fit O_O
And especially with phones getting thinner and thinner, every time my heart will skip a beat when I feel like my phone is getting snapped into 2 in my tight pockets :/
won't have such problem with the G Flex 2 :D
WhiteAnt
G Flex curve can fit into the back pocket just nice the pigu shape :s13:
mmm your jeans a bit tight means.......
you buibui already :crazy:
_MaOMaO_
Here are some pictures from the LG G Flex 2.
The LG G Flex 2 features OIS+ and laser auto focus. These two technology helps you to take picture faster by focusing faster and reduces the effects of camera movement respectively.
Tardis
the LG flex 2 can withstand at least 25kg weight.
with the LG flex being able to withstand 40kg for 100 times, I guess the successor can do probably the same too
thunderskain
The red colour one looks quite nice. Plus the curved screen really makes it stand out as a phone. If only my g3 has such curves too..
thunderskain
Won't 50kg be too much on LG Flex2? Later cannot flex anymore lol, need reviews on this.
Cos 50kG should be the estimated weight it has to withstand especially when a human butt is pressed onto it. If it can only withstand 25 then might as well not add that feature in already :s22: but nonetheless must check it out then will know ah. And as for the surface it's pressed on, makes a difference too for example putting it on a chair and exerting the weight might not have much impact than putting it on a concrete road.
MoneyFace =p
You tell me which other phone can tahan a human's buttock force? :s22:
shadow84
Communications
The phone comes with Wi-Fi 802.11 a/b/g/n/ac, dual-band, Wi-Fi Direct, DLNA and hotspot.
One point that I would like to mention that hotspot is really a very useful feature to have. I have used the hotspot feature numerous times. Back then when I was a student, I activated the hotspot function on my phone so that my laptop can receive internet at places where there are no wifi.
Also if you have other devices that does not have internet access, you can also tap on the hotspot internet connection from your phone.
This is a great feature to have and it is present in the LG G Flex 2
Other features
The LG G Flex 2 has the ability to fast charge battery. The phone is able to charge your battery to 60% within 30 minutes. This is a great feature to have. Perhaps you might be using your phone the previous night and played games till low battery and fell asleep. When you wake up to prepare for work and you realise the battery is low.. fret not! Because when you prepare to go to work you can charge the phone and within 30 mins it will be at a healthy level to last for the whole day!
Battery
The phone comes with a large capacity non-removable Li-Po 3000 mAh battery. In my opinion there isn't really any difference between a removable or non removable battery. My current phone is a removable battery phone but to date, I have not removed the battery yet and see no need to do so.
Aint all modern smart phones have hotspot function? This one got what difference?
kurt111494
Actually I'm underweight haha. But I think be it fat or skinny, everyone will sorta meet the same problem >.< With the G Flex 2 there should be less worries hahaha
WhiteHunter
50 kg is the average weight for ladies and i dun think they put the phone in back pocket. usually guys are the ones that will sit on the phone with it in back pocket so at least it must be able to withstand around 70 kg.
i rather they make the phone to be able to withstand all sort of drops or damages. this is much better than the flex feature.
