What The Flex can the LG G Flex2 do?
fireduke86
Cannot, later naked photo sexposed inside the cloud storage!
That's why preference is an extra 128gb microSD slot.
:crazy:
At least can remove from phone before sending it in for servicing and becoming famous for the wrong reason? :crazy:
jeff79
heat issue with this processor on LG G Flex 2 is easy fix with software update.
Software fix is throttle the cpu performance same as htc m9. IF they throttle the cpu, might as well use older 801 or 805 in the LG FLEX2.
koreanlover
the difference is that this time most of the people here including me will be wasting our time or just join for the fun of it cos there are only 3 units to redeem.
to know whether you can be the first 3 to redeem is if you are able to increase your points at around 10-11am everyday if not you are just joining for fun like me.
Hopefully there are more than 10 units of the LG G Flex 2 for redemption.
Kaer
snapdragon 810 - think so far only g flex2 out in the market.
powerful 64-bit octa-core blazing fast? but also blazing hot.
htc one m9, sony xperia z4, the china brand phones like letv, mi note also will be using but can't test yet.
fireduke86
Per prize description Flex2 is worth $998, G4 should be more than that or no??
I would expect the G4 to be cheaper because its manufacturing cost should theoretically be lower due to its conventional shape~ :o
#LGHotCurves
#whyedgehalfway
#LGGFlex2
‪#‎LGMobilePhotography
Alexz_Hong
There are only 3 as stated. I highly doubt they will increase it to 10 units of G Flex 2. Increase more printers more likely. lol. Like WhiteHunter has said, unless you joined early on the first day, your chances are alraedy pretty low. There is a fix number of points you can earn daily, and that 24 hours cycle starts from the first time you post here. So unless you can earn points on the day people can get to 1000pts, you're out of the running. Unless all those who has max points now suddenly bo eng to post for a day or 2.
Ohayo!
this time i feel too little la the prize
previous microsd at least more people got chance to win
fireduke86
Those aren't 64bit like the SD 810 but it's not as if 64bit plays a big part in performance now~ :o
jtec14
#LGHotCurves
#whyedgehalfway
#LGGFlex2
G4 seems to have the more premium feel, pay more for premiums....
