What The Flex can the LG G Flex2 do?
WhiteAnt
Lol... Xiaomi (CN) got free 1 year replacement for any damages including crack, drop in toilet bowl etc
Xiaomi very aggressive! Making the big players having a challenging time these days. XM diversify into many lol.
LG should join in to find products that appeal. Don't waste their resources since already in gadgets.
xtramadness
The LG Flex 2 gives and provides an ergonomic hold on the phone which should sit pretty comfortably on your palm. Together with its large crisp 5.5" screen that sports a 1080p resolution and coupled with 2GB or 3GB ram, 16gb or 32GB of internal memory respectively, it has pretty much everything that an average user needs to run his stuff daily on a phone.
Including the of up to 128gb microsd for expandable memory (well, funny because 200gb is now out), you can carry all your memories together
Why the twin model with 3GB ram and 32gb internal memory or 2GB ram and 16GB internal memory might be puzzling but probably costs?
It will be running on the latest Android OS - Lollipop
POLED in Full HD 1080p screen, resulting in a resolution of 403ppi.
The screen is protected by Dura-Guard Gorilla Glass 3
With the heart powered by the latest Qualcomm Snapdragon 810 quad-core processor running 2Ghz, it also supports native 64bit processing
OIS+ on the 13 MP (megapixel) camera for the back (rear) with 4K high-resolution video recording and 2.1 megapixel at the front, it offers something new that others do not support - using laser to do auto focus
Battery is rated at 3000mAh...
The self healing back of the LG G flex2 is interesting because it will help maintain the "pristine" of the device from daily wear and tear, so will the resell value be higher?
#WhyCurveWrongWay #HotCurves #SexyCurves
xtramadness
#hotcurves is available in Platinum Silver and Flamenco Red
From the website:
With no side buttons interrupting its design, the curved form factor of the G Flex2 is both easy to hold and intuitive to operate.
The uniquely curved 5.5 Full HD Display delivers more immersive and lifelike viewing experience. The curved display phone creates optimal viewing angles to minimize glare and reflections.
Always look your best with instant Self Healing Technology that naturally fixes scratches and blemishes to help your G Flex2 maintain its timeless look.
Capture photographer quality shots with LG’s superior OIS+ that steadies every shot for sharp focused images. And with Touch & Shoot you can touch anywhere on the screen to capture stunning images in an instant.
GESTURE SHOT & GESTURE VIEW
- No more stretching out your arm and struggling to press the shutter button. Take a better selfie without pushing any buttons by making a simple hand gesture.
- Instantly see your latest selfie creation as the Gesture View feature opens your photo gallery as soon as you lower your G Flex2 camera from position
Find the power you demand to multitask at blazing speeds with the Qualcomm Snapdragon 810 processor with (integrated) 64-bit Octa-Core CPU and today’s latest Android OS.
Spend less time charging and more time doing what you love with accelerated charging that refuels 50% of the battery in about 30 minutes.
Conserve battery power and time with Glance View. Check the time and other notifications while the screen is off simply by dragging down on any part of the screen.
Check out the smartphone options offer a wide range of features, such as 3D technology, Wi-Fi Hotspot, IPS displays and more.
xtramadness
You can read reviews. Some say it's not an issue. Some say it got warm easily. Overheating is definitely exaggerating. Modern processor all have thermal sensor. Once it gets too hot, it will throttle to cool it down. It won't "over heat" unless there is a hardware fault. :s13:
But i do believe that the 810 runs hotter than Qualcomm's older phones. Playing with the demo units for a short while causes the phone to heat up a little already. But personally i think it's nothing to be worried about. It's the UI and performance of the phone i'm more worried about. :s13:
Oh, and G Flex 2 was the first to use LDPPR4 RAMs too. LG cramped a lot of new tech into the G Flex 2.
I told u it gets hot #HotLG #HotCurves #HotCurve
WhiteHunter
From the website:
didn't know got no side buttons. always thought there are power and volume buttons by the side.
WhiteHunter
Eh.... How many are there prizes for #LGHotCurves #whyedgehalfway #LGGFlex2 ‪#‎LGMobilePhotography #SexyCurve #LGSexyCurve :s13:
3 phones and 5 pocket printers so total only 8 guys can win.
#LGGFlex2
#whyedgehalfway
#LGHotCurves
WhiteAnt
From the website:
The hand gesture to take photo very good. Always have problem stretching out to take selfie or sometimes one person hold the other person press very silly. :s13:
#LGGFlex2
#whyedgehalfway
#LGHotCurves
#WhyCurveWrongWay
#HotCurves
#SexyCurves
xtramadness
#LGGFlex2
#whyedgehalfway
#LGHotCurves
#WhyCurveWrongWay
#HotCurves
#SexyCurves
Pretty sure is just software though...
WhiteAnt
Only LG has this right? Or other phones also have? Like the Knock Code security to unlock phone. Probably is a intellectual property and proprietary thingy. When knock knock first came out, my friend who owns G2 showed me and I was intrigued by it. Very suaku of me. :s13:
jeff79
POLED vs AMOLED? Which one better?
Both are same technology by different marketing term? Amoled should be better, as it has passed more generations and the korean company had pumped in massive amount of money in R&D.
Hardwarezone review said POLED has grainy pattern?
Mockingjay
LG G Flex have these features:
Curved and flexible P-OLED screen
Gorilla Glass 3 with Dura Guard coating
Self-healing backing
Camera Laser focus and OIS+
Qualcomm Snapdragon 810 with Adreno 430
MoneyFace =p
Think Dr Vijay got hint hint...think positive when someone asked about removable battery
Alleged leak image of G4 back.... :D
No need NDA liao :s12:
http://www.gsmarena.com/lg_g4_dual_simversion_leaks_with_extra_details_and_images-news-12013.php
jeff79
Should not be unique to LG only. Many OEM like sony, oppo, oneplus also have the double tap to wake up. Samsung was testing firmware with tap on side of phone to take photo in the stock camera app but not sure why it was not implement in official firmware.
