Help on Ethernet (internet) connection
Z_Assassin
Hi. I recently got an Asus Hero VI mobo (intel 4770k chip).
I use starhub broadband at home (Motorola surfboard modem).
So to get internet connection, what I did was to install the mobo driver for LAN connection and then I got online using direct cable connection from modem to mobo, all is great.
However, the connection cannot be detected upon next boot up, so I uninstalled and re-installed the same LAN connection driver and I got online again for that session.
This however keeps recurring on each and every boot up, ie. I have to uninstall and re-install driver before I can go online.
Troubleshooting is unable to identify the problem, although when I look at the log, it says issue with hardware adapter or something.
I cannot be uninstalling and re-installing the driver with every boot up. Does anyone know how to solve this problem?
Thanks!
micheloving
Might be some other driver interfering .
Make sure your driver is the latest from the mb site or use slim drivers .
Go device manager when the error occur to see if theres any driver interfering and uninstall/disable it .
halnala
Try different versions of the drivers. Sometimes updating drivers may not necessarily a good idea.
jtjt00
Look like a domain account which erase all settings upon reboot.
Z_Assassin
Thanks, but how do I know at Device Manager whether any other driver is interfering? Sorry but I'm new at this.
Z_Assassin
Thanks, but the problem is only confined to the online connection, all other settings still there. But is there any way to test your suspicion, should I do something to my comp?
Z_Assassin
Firstly thanks for all the help, I deeply appreciate it.
An update that yesterday I un-installed the anti-virus (that came in the mobo driver disk, no less) and the problem was solved. So that anti-virus (starting with "K") wasn't compatible with the intel ethernet driver. For info of those who meet this problem in future.
Peace out.
