Z_Assassin
- Mar 29, 2004
Hi. I recently got an Asus Hero VI mobo (intel 4770k chip).
I use starhub broadband at home (Motorola surfboard modem).
So to get internet connection, what I did was to install the mobo driver for LAN connection and then I got online using direct cable connection from modem to mobo, all is great.
However, the connection cannot be detected upon next boot up, so I uninstalled and re-installed the same LAN connection driver and I got online again for that session.
This however keeps recurring on each and every boot up, ie. I have to uninstall and re-install driver before I can go online.
Troubleshooting is unable to identify the problem, although when I look at the log, it says issue with hardware adapter or something.
I cannot be uninstalling and re-installing the driver with every boot up. Does anyone know how to solve this problem?
Thanks!
Thanks!
