What The Flex can the LG G Flex2 do?
Picory0
LG G flex 2 is lg product. Camera heard good. Use riao life good. Social media also good. Run by android as good. When lg giving free good phone?
Lol.
koreanlover
06 May 2015, 17:50, by Alan F.
Qualcomm’s VP of marketing, Tim McDonough, says that the Snapdragon 810 never had a heating problem. Speaking with business magazine Forbes, the executive said that all of the rumors about the chipset running hot were "rubbish." McDonough did admit that early versions of the HTC One M9 and the LG G Flex 2 did overheat, but those were devices being tested and were not for commercial release.
http://www.phonearena.com/news/Snap...device-says-Qualcomms-marketing-chief_id69026
Hmmm Qualcomm says the Snapdragon 810 in the LG G Flex 2 has no overheating issue.
koreanlover
Just saw this news...
Xiaomi boats faster Snapdragon 810 chip inside the MiNote Pro.
"But the phone might just have another trick up its sleeve. According to Xiaomi, the MiNote Pro uses a newer version of Qualcomm's top-of-the-line chip. The SoC it has is a v2.1 model, which the manufacturer claims gives it a slight edge in performance over other phones with the same Snapdragon chip."
Maybe the v2.1 solved the heat issue.
http://www.gsmarena.com/xiaomi_boats_faster_snapdragon_810_chip_inside_the_minote_pro-news-12172.php
The 810 in LG G Flex 2 is what version ?
jtec14
i think nope ba since got other brand also ads same quick charging like LG G flex 2
I believed the question is whether must both battery and charger be able to support fast charge or only charger matters...
xtramadness
The keywords for taking photos used are Cheese, Smile, Whiskey, Kimchi and LG
SHe used palm and fist for selfie.
LGGFlex2 people will say what the flex as it is flexible bendable great for selfie
Screen powered with a Plastic-OLED or P-OLED back with Self-healing technology
Camera empowered with Laser-guided autofocus, OIS+ Camera, Gesture Shot, Gesture View and Knock Code
I prefer if they used something more cheesy for the keywords
xtramadness
The LG Gflex2 hotcurves is available in Platinum Silver and Flamenco Red
From the website:
With no side buttons interrupting its design, the curved form factor of the G Flex2 is both easy to hold and intuitive to operate.
The uniquely curved 5.5 Full HD Display delivers more immersive and lifelike viewing experience. The curved display phone creates optimal viewing angles to minimize glare and reflections.
Always look your best with instant Self Healing Technology that naturally fixes scratches and blemishes to help your G Flex2 maintain its timeless look.
Capture photographer quality shots with LG’s superior OIS+ that steadies every shot for sharp focused images. And with Touch & Shoot you can touch anywhere on the screen to capture stunning images in an instant.
GESTURE SHOT & GESTURE VIEW
- No more stretching out your arm and struggling to press the shutter button. Take a better selfie without pushing any buttons by making a simple hand gesture.
- Instantly see your latest selfie creation as the Gesture View feature opens your photo gallery as soon as you lower your G Flex2 camera from position
Find the power you demand to multitask at blazing speeds with the Qualcomm Snapdragon 810 processor with (integrated) 64-bit Octa-Core CPU and today’s latest Android OS.
Spend less time charging and more time doing what you love with accelerated charging that refuels 50% of the battery in about 30 minutes.
Conserve battery power and time with Glance View. Check the time and other notifications while the screen is off simply by dragging down on any part of the screen.
Check out the smartphone options offer a wide range of features, such as 3D technology, Wi-Fi Hotspot, IPS displays and more.
xtramadness
The LG G4 and the LG G Flex 2 aren't too dissimilar, apart from when it comes to physical design. The actual footprint of both is near enough the same, give or take a couple of millimetres, and while the LG G4 is slimmer, the LG G Flex 2 is lighter.
The displays are the same size and while the G4 has a higher resolution, which should mean a sharper and crisper image, the G Flex 2 offers a curve instead. Both have the same storage, the same battery and they both offer the same RAM support but the LG G Flex 2 has a faster processor.
It's the camera where the G4 takes a few strides ahead of the G Flex 2, delivering more megapixels and a larger aperture on both the rear and front snappers, as well as a few software extras. The G4 also comes with LG's new user interface but this isn't likely to be a deciding factor as both come with the latest version of Android.
The decision between these two smartphones probably won't come down to the specs. It will come down to which design you prefer. Do you want something unique and different, or do you want a smartphone that could offer one of the best cameras out there at the moment?
http://www.pocket-lint.com/news/133796-lg-g4-vs-lg-g-flex-2-what-s-the-difference#
LG G4's camera seems to be much better than LG G Flex 2.
I dont think I am surprised...
koreanlover
LG G4's camera seems to be much better than LG G Flex 2, even though both have OIS+ and laser auto focus.
jtec14
Funny why G4 as a flagship are not using the latest Qualcomm chip
koreanlover
Does LG sell a leather back cover for the LG G Flex 2 for those who do not care about the self healing back ? It can complement the sexy hot curves for the phone!
koreanlover
long term heat will cause electronic to breakdown faster lo~ maybe LG G flex 2 suffer heat issue long term when just nice 1yr warranty end it break down.
Does the heat issue cause the LG G Flex 2 to lag and crash when playing games ?
If just nice warranty over then break down really suay man.
koreanlover
I wonder whether the POLED screen is visible under the bright sunlight.
Any sample photos of fast moving objects showcasing the OIS+ and laser autofocus of the LG G Flex 2 ?
koreanlover
Think both battery/phone and charger must be able to support fast charge for it to work.
Nakedtoes
of cos no heating problem... cause before heat up already throttle :s22::D:D
