poor_poor
Hi, my firmware is 3.0.0.4.376.2769.
When trying to set up AiDisk using the Wizard, I get this error "Invalid IP Address!" when trying to create the domain name.
Can somebody help me please?
1 sentence for you :)
Go to support site and download latest firmware and install.
sohcheekeong
Should I download the firmware from support site or can I also upgrade the firmware according to the manual, Advanced Settings > Administration > Firmware Upgrade?
GeForce
download from support site.. the update thing from the router's web GUI doesn't even seem to work.
sohcheekeong
Ok, done. Instruction asks me to reboot the router manually.
How do I do that?
Switch off everything and then switch on again? Or press that red button behind?
ASUS@SG
Suspended
Dear sohcheekeong,
Please do hard reset after update to latest firmware.
Best regard,
JK
GeForce
How do I do that?
For your case, do a hard reset. Press and hold the reset button behind the router for a few seconds. Afterwards, just set up the router from scratch.
ASUS@SG
Suspended
Dear all,
I will be releasing another beta firmware for RT-AC87U. This firmware contains a lot of fix bugs and improvement.
RT-AC87U_3.0.0.4_378_5556-Unofficial Beta Firmware
Update dnsmasq to v2.73rc4-1
Update to brcm sdk 6.37.14.105
Update support Territory code
Update [IPTV] Add Meo profile for RT-AC87U
Update User interface
Fix GUI bug
Fix 5G WPS pincode 12345670 issue
Fix NAT loopback issue
Fix [dualwan] disable 3rd 5G guest network and wan2 used its mac address
Fix dead loop message only for vlanX case
Fix Traffic Monitor can not display correctly on Wired traffic
Fix [Adaptive QoS] WAN is DHCP Traffic Monitor can not display the WAN Download / Upload flow correctly
Fix [Adaptive QoS] [Traffic Monitor issue] Traffic Monitor "Wired" is not displayed correctly flow (WAN, wireless normal)
Fix [Traffic Monitor] Traffic Monitor without any display.
Fix [Administration] Save Profile check Transfer ASUS DDNS name leads to abnormal profiles
Fix [Wireless] happened some time after power 5GHz disappearance could not connect
Fix [Administration] in the presence of some settings can not successfully update the firmware
Important Notice:
Require hard reset.
Do not restore configure settings due to driver update.
Download: http://goo.gl/ZQByAz
Please feedback to me.
Best regard,
JK
renfred89
Dear all,
Fix GUI bug
Important Notice:
Require hard reset.
Best regard,
JK
Looking at the fixes, I think I made a wrong decision jumping to ac3200.. :(
woshi]x
Dear all,
Fix GUI bug
Important Notice:
Require hard reset.
Best regard,
JK
Will this fix the 5ghz drop issue on Samsung S6 edge and iPhone 6 plus?
Jurong640
Dear all,
Fix GUI bug
Important Notice:
Require hard reset.
Best regard,
JK
this update seems to solve the traffic monitor issues. The traffic monitor after some while, it cannot track the traffic. Wired traffic also no show.
:s13: Hopefully next next update can get dc issues solved
sentinelvdx
Hi, so far the only 2 things I've found were:
-Unable to add my alias on asus ddns domain: Error Pop-Up "Request Error! Please try again." or "Unable to Connect to the Internet" (when I'm navigating without issues)
-Each setting I apply, no matter what, takes at least a minute more than with previous firmwares (5134-4950-Etc)
I will continue testing it.
Thanks,
ASUS@SG
Suspended
Hi Renfred89,
RT-AC87U still got lots of room for improvement, that's why I didn't upgrade to RT-AC3200 :)
Anyone using ASUS DDNS, please help me test.
Best regard,
JK
thiamhui
Hi Renfred89,
Best regard,
JK
No issue with ASUS DDNS.
May 14 08:28:22 rc_service: httpd 464:notify_rc restart_ddns
May 14 08:28:22 ddns update: ez-ipupdate: starting...
May 14 08:28:22 ddns update: connected to nwsrv-ns1.asus.com (103.10.4.108) on port 80.
May 14 08:28:22 ddns update: Asus update entry:: return: HTTP/1.1 200 OK^M Date: Thu, 14 May 2015 00:28:22 GMT^M Server: Apache/2.4.9 (Unix) PHP/5.5.14 OpenSSL/1.0.1h^M X-Powered-By: PHP/5.5.14^M Content-Length: 0^M Connection: close^M Content-Type: text/html^M ^M
May 14 08:28:22 ddns update: retval= 0, ddns_return_code (,200)
May 14 08:28:22 ddns update: asusddns_update: 0
May 14 08:28:23 ddns: ddns update ok
ASUS@SG
Suspended
Dear all,
Did you guys realize the new beta firmware got new login screen?
Best regard,
JK
thiamhui
Dear all,
Best regard,
JK
The new login screen, no longer can save ID and password for Internet Explorer. :( But able to save for iOS Safari...
Is this what we call give and take? :s22:
ASUS@SG
Suspended
Dear Thiamhui,
It's trend not to save password :) Just like 007 james bond, he don't save any password too.
Best regard,
JK
Jurong640
Dear all,
Best regard,
JK
haven update yet. Cos still beta firmware right. I wait for actual release. Hopefully next time the interface could be changed with softer look like how the login page is. One example could be the Android Lollipop
