crazy1k
not going for the god-hand :s13: too crazy price
hmm what number is that for sharp pointed ?
surely personal opinion is ok. but whats the difference ?
Both the 35 and 123 are sharp pointed, except that 123 has a slimmer jaw. That's for when the parts are too close together for a "wider" jaw cutter to go in. Actually, it boils down to preference. For me, 35 is good enough. Others like to snip close and flush to the parts, so 123 will be a better choice.
But when the jaw for the 35 cannot fit in properly. I'd use a cheap $6 side cutter (for rough use) to snip the whole chunk out and finish off with the 35. :)
crazy1k
tried to paint the pilot that came with the RG strike freedom, gawd my eyes hurt.:s22::s22:
My eyes hurt just looking at the pic. lol
crazy1k
Hi guys,
I'm thinking of buying full resin kits or conversion kits from taobao, but need help as I don't know what is the mandarin term for resin. Don't know how to search for it. :)
Can try this - 高达树脂改件 for resin kits, add GK as it seems to be quite a popular term. Or 高达武器/零配/改件 will give you mod parts.
If you find any good resin kits must share hor..
Errz
anyone know if Bandai did release water decal for PG XXXG-00W0 Wing Gundam Zero Custom?
Errz
just notice PG Unicorn doesn't have water slide decal. it only comes with the Full Armor Parts set! *un .. un .. un..believable ....* :s13:
xiaodark
Hi can someone reply me fast? Is the mr hobby side cutter good? As compare to tamiya side cutter?
AppleStrudelMudPie
Anyone here have experience buying gunpla from yodobashi akiba ? Other than stffing everything into luggage, is there any other way to bring back your loots ? Thanks in advance :D
zenningout
Anywhere to recommend to buy? Mainly looking to buy some seed n seed destiny models but more interested in getting Heine westenfluss customs
Sent from OnePlus A0001 using GAGT
Albedo
Me. I bought 2 RG, 1 MG, 6 SD. All stuffed into a large suitcase.
When I buy kits in Taipei, I have them sent by sea ship to me. Not sure how to do this in Japan though.
