Xiaomi Redmi 2 4G
amazingone
laironpark
For Meizu M2 Note, the 1st SIM slot is for nano SIM card, while the 2nd SIM slot uses micro SIM card which shares with microSD card. That means if you put in your 2nd SIM card, there is no space microSD card.
Check out the review:
https://www.youtube.com/watch?v=UifMBV4-glE
cscs3
Yes, still this is a better design compared to Mi4i which has no SD card option. It still win Redmi 2 in term of Andriod 5 out of box, faster processor, bigger screen and battery capacity.
Ybother
Redmi 2 Case
hello, i m looking for cases for Redmi 2. Want a tough case that feels good and protects screen from drop.
I have bought some online but they need time to come and I need quite a few as I need to use them next week.
Anyone knows where I can good case?
If i can find this, it will be the best
Previous ones I bought is this. Ok to settle for this for now
any other recommendations is welcomed too.
kchinbeng
First time ordered a xiao mi and first time owning a xiaomi also.
Just ordered a redmi enchanced version.
Normally how long do they take to deliver to my house?
Please advise.
Thanks in advance.
Solkarnar
Please advise.
Thanks in advance.
about 3 days usually. mine usually come in 3-4 days.
cscs3
You run out of Ram or not enough memory to install new apps ? If not, no need. Just continue using until new model comes. My 2cents.
Yes, dont waste your money on Xiaomi. There is better one in market at around the same price.
k0g3pAn
bro whats your recommendation for other same price model? i also trying to source one best value for money phone to buy for my mum...
juuzbe
But with $179 you able to get 2Gb RAM and 16Gb storage and Dual SIM considered not a bad deal already. They also have the LITE MODE for senior people who cant get use to the usual Android OS.
cscs3
I think you can look back. Already a few recommendation. Personally I think M2 from Meizu or Asus is good choice little more, but faster processor and already factory ship Android 5.
csc12345678
Zenfone Asus Zen 2 ZE 500CL is dual core while this is quad core, right ?
Can give me some quick pointers what I give up if I'm not on lollipop ? Being lazy to check. Thanks if anyone can help.
