The Hair Thread - Part 4
netzach
Any good hairstylist to recommend?
Please PM the IVERSON dude, he is a Tier 1, Type A hairstylist, and I'm positively sure that he'll give you a MAGICAL hairstyle. The IVERSON dude cuts for the Deejay guy here also. :) :o
deaththeorist
damn right! i just wanted to say the same thing before you edited. He's the reason why i'm called Deejay.
netzach
Absolutely right. IVERSON dude is a legit Tier 1 hairstylist. You get what you pay for. This IVERSON dude can cut a Deejay, G-Dragon, McK, GS, or even Mickey Mouse style for you if you want. IVERSON dude cuts for me the Mickey Mouse style. :o :)
derazor
My abang barber us tier 1 to me
Mogan23
Wl you also use leh.
Only Kent that let me down was the cushion brush. All the bristles drop lololol. But my other brushes and combs all doing fantabulous. Got like 7 of their stuff
Sent from a based SONY using GAGT
I just use a normal $1 plastic comb :s13:
Really need satki combs meh???
Anyways, I just did a clean shave today. Had much more hair than I originally thought :s22: going for a haircut soon, maybe I'll try dapper's lobang and post fr here :o
deaththeorist
Don't need la! But shiok ma. Try one u know liao. Diff feeling one. Last time I use the free combs from qb hse. After iverson service my hair, I know better liao
thisisnotme1212
hello everyone
currently i'm using the pink gatsby (i know a lot of people say gatsby is a bad brand) to achieve a brush up/back comb hair, but when my hair gets longer it can't hold for long anymore
the question is if anyone can recommend me any wax that'll be able to achieve brush up/back comb hair with strong hold
Sent from HTC One_M8 using GAGT
y is gatsby a bad brand?
i'm also using the pink 1. doesn't hold my long hair too.
this thread of the elites?
got budget stuffs to recommend?
gaoxing84
It's not a bad brand ah. It's well marketed brand. Off the rack generic brand for the mass.
Maybe ingredients used to Made it isn't as good and washibility maybe an issue.
Everythread in hwz is for the elites. If you can register for hwz. Means you have either a smartphone or a pc. Which also mean you're elite enough.
If you want budget and good. Try ebl Clay or vantachi. Google the pretty jerk.
Solid seller with good stuff.
Those recommended are $20 below.
Shld fit your budget. Given the moving rubber cost like $10-ish
gaoxing84
Clean shave where? Pls be more specific lol
