Yes, definitely. Both 818P and 818N successful. Not difficult. Just follow the instruction carefully, it will succeed. No data lost, except for one thing. If your micro SD is using exFat format, it will not support. You have to format your card back to Fat32. I guess this is due to the kenel.
Sent from Shaolin Temple using GAGT
my sdcard unable to copy 4gb img file into it due to size limit..how to resolve this?
thanks
last week, i bought h818p from mr joe
ww.myaparato.com/lg-g4-leather-dual-sim-lte-4g-h818p-32gb-mobile-phone/product-1355655.html
and i can confirmed that the h818p (10d-ame) from this seller support 4g on second sim by changing to gsm for 1st sim and vise versa..
you cant activate both 4g at once.
It's the same for HK 818N.
I'm using the N version from HK. I can select LTE on sim 2. So conclusion, both P and N are the same. And the best for N version, u can even select the LTE band under the hidden menu 277634#*#. Meaning if I travel to Australia or even china, I can switch to their LTE band. For SG, it's under LTE band 7 iirc.
hi, i just try by using your code and i can see the "lte band selection" in h818p too...so conclusion they are most probably 99% same..
but looking at the method to activate other band, looks like not that easy
f forum.xda-developers.com/g4/general/guide-enabling-lte-bands-t3137818
i saw the price is 686 instead of 666. has the price increased?Lazada selling at $666, gd deal?
Can get additional discount if new registered acct right?
http://www.lazada.sg/lg-g4-dual-sim-h818-32gb-black-export-736289.html
But got buyer feedback say its a H818N set from UAE..the LTE bands works in Spore?
Finally, someone proven what I said previously is true. P and N basically are the same.
this is only true after the recent 10c firmware upgrade...before that it was still not working
So the P (Indonesia, Thailand, UAE) has less bands than N (China)? I bought p thinking it would support western countries better than N
Yes! I finally get my LG G4
http://www.myaparato.com is one of the great seller I ever meet. Simply awesome! Highly recommended.
My first impression on LG G4
- Simply Elegance.
- Solid build even though not uni body.
- The IPS Quantum screen is simply outstanding! Wow!
- Camera focusing is extreme fast which S6 Edge is no way to fight with.
- Smooth performance in overall, no complain.
What I dislike and shall be improve
- The LG stock keyboard is the worst keyboard I ever use! It is not really smooth and the swipe recognition is simply unusable! I already switch to Google keyboard as using LG keyboard probably will shorten my life!![]()
- Camera is not a wide as S6 Edge camera.
Is LG G4 Dual SIM H818N Hong Kong edition both SIM support LTE? I can assure also YES it is support as long as you upgrade to latest 10C firmware.
