TV repair discussion thread (consolidated)
Terence Ho JH@Bank
Hi, I have a 32" Samsung Smart TV power failure can't turn on.
I'm not sure if PCB got problem? If repair need roughly how much?
Model: UA32EH4500M
open
open
freakinclown
Feeling sad here. My 3+ year old Samsung UA55D7000LN which is so lightly used suddenly after 20-30 minutes of watching has vertical lines appearing. Not too many lines but very noticeable on some coloured backgrounds.
Would any of you know if this repairable and at what cost?
Thank you so much. I appreciate all the help and advice.
Unfortunately, it is likely that the panel is faulty, hence this issue. Panel replacements are typically expensive, and it will be more cost effective to replace the tv instead.
cLip6z
Hi guys, my Samsung p2370 LCD have flickering screen sometimes even black screen. I googled and it seems to be the capacitor that is the one causing the problem.
Is there any places I can bring to solve this issue and whats the usual cost of it.
i1magic
Yes. Or could be the LED backlight PCB is failing. Perhaps you can open up to check and see any blown capacitors first?
i1magic
The board as shown, I dont really see any popup capacitor.
Maybe you can google for the model + the symptons and see whether can you find other user who got similar problem and how did they resolve it.
Jeremy1
Luckily still under warranty. This is the 3rd time they are coming again to my house to fix the issue :
Screen as above while streaming and watching through usb.
First time, technician did a hard reset. Second time, technician changed the hub. This is the 3rd time liao within a year.
Very doubtful they can fix it. :o
SpinTop
can share what brand, is it lcd, plasma or led ?
so that bro and sis here can be wary.
i find led tv to have a higher failure rate that those older lcd tv.
Jeremy1
Samsung UHD 55HU9000.
Think maybe they will changed a new one 4 me liao. :s12:
SpinTop
knowing tv nowadays failed in short time, i alw buy extended warranty for added insurance.
imagine if tv failed just after 1 year, i will be very pissed. and you cant do anything about it.
Jeremy1
imagine if tv failed just after 1 year, i will be very pissed. can you cant do anything about it.
Mine is with 3 years warranty.
SpinTop
u shd insist for a new model.
tell them u lost faith in their (1) repair service and (2) product quality
(3) dont waste time repair known problematic and poor design tv model.
hehe
Jeremy1
hehe
I will asked them this Thursday.
But very doubtful is the panel problem because watching normal TV program is ok.
Still think is the hub.
xiao.xin
Hi Bros,
Any idea about HDMI port not displaying? Has been fine using last week. It can be detected on my laptop, but the display is just blue screen.
Model: Toshiba 32P1300VE
Thanks in advance
i1magic
Have you asked them "What if my TV spoilt liao, after standard warranty but within the extended warranty and the manufacturer already EOL this model?"
From what I heard, they'll just give you some discount and ask you to buy another new one. But the discount is lousy one.
Jeremy1
I can answer that question.
Not really sure about other shops but for Harvey, if you buy the extended warranty and if the product EOL and there is a fault that cannot be repair, they will replace you with a brand new model of the same price as your faulty TV.
Of course, you can top up more if you wanted a bigger or more expensive model.
i1magic
Ok. Point taken. Did you personally read this somewhere? Or you personally experienced this before?
dankoo
Anyone has their Panel died before? My Samsung TV suddenly has a dimmed top portion of the screen and after a while the tv will keep rebooting. Samsung sent their 3rd party contractor and he just on the tv and tell me its the panel spoil which costs above 1K to repair without further diagnostics. Got to pay $80 for that 1min service...I felt that its not justifiable if no further checks done. What if it is smaller issue and can be repaired $100-$200?
i1magic
How old is your TV? I rather pay $80 than to bring my TV all the way to them to be checked and pay say $20-$30.
Anyway, I Google-ed and YouTube-ed how to troubleshoot my own TV and it seems that the panel is spoilt. So bo bian liao ... must buy new one.
Henry Ng
Earlier my Sony Tv having the same issue and confirm it is panel faulty.
