[OFFICIAL] Taiwan Guide and Taiwan related matters - Part 7
Gixxerfied
budget around 150 per night... probably travelling by train... that's why hotel located near train station best.. but still at city area probably xmd or taipei 101 there...
Near TMS is ur best bet if not XMD..Taipei 101 is far from the main transportation hub of Taipei Main Station...
ITretard
lool.. end up coz of budget.. booking v one vouge hotel... wanted the fx hotel.. but too expensive.
calkel20
Cityinn not bad.
Taipei 101 has no nearby train station.
So still stay ard tms. There is ymca, ceasar etc.
Also a few little known ones.
When are u travelling?
yuihatano
How to get from Keelung to Hualien (I stay Arsma Hotel so is Hualien Station?)?
I read from the net it from Keelung to Badu and then from Badu to Hualien. But I went to TRA site cannot find from Badu to Hualien train for all days. Strangely I found all from Shulin to Hualien
twosix
Gixxerfied
now 101 is easier to get to with the opening of the newer mrt line..
Same lar...
It's still a few stops from the main hub... :s13:
And 90% of the time, you would have to get off at TMS to change line/transportation mode..
XMD not so bad since just 1 stop away..
Staying nearby can just walk over and board the transport direct..Nt forgetting last day with luggage just walk to bus terminal for airport..
new_bie
anyone can share ..
From Chiayi to alishan, how far & what sort of transport other than cab is available??
From sun moon lake to green green glassland, how far & what sort of transport other than cab is available??
& lastly how to go to puli brewery factory?
thanks
Gixxerfied
taipei Keelung station to Hualien Hualien station? I search don't have train for everyday?
http://www.railway.gov.tw/en/timeta...i=1715&st=00:00&et=23:59&t=express&sa=14&ea=3
When you search, it will show up as start to end station..
For example if you search from Qidu to Hualien and if it shows up as Shulin->Taitung, it means it starts from Shulin and ends at Taitung..And inbetween it also stops at Qidu and Hualien..
Use this old site, it gives u a better idea..
http://twtraffic.tra.gov.tw/twrail/English/e_index.aspx
After the search results is out, click on the train code of that particular train and it will give u a popup showing the station it stops at and the time..
Gixxerfied
anyone can share ..
thanks
Can only help u on the 1st..
Bus if not cab..
From Chiayi HSR, about 3hrs to the top..I believe bus timing not as frequent as at Chiayi TRA station which is about 2+ hours to the top.
If planning on train wise, TRA from Chiayi TRA Station only brings you until Fenchihu which is about 1hr away from the main area..
deepblue_82
Same lar...
now xmd is more like a mini tms la..
i took cab from xmd to tms.. 85nt... worth like mad.. haha
