[Maylyn's Preview ~ Networking] ASUS RT-AC68U
Ah-Pin-Kor
i mean i keep setting it cause it ressets it self... im using stock firmware 378_4585, how do i prevent this?
If the settings cannot be retained, might be a hardware problem.
Bring it down to Avertek to confirm.
Dellboy
Fix some bug... :)
Is there any issue on this build?
Best regard,
JK
JK, need your advice.
I'm still on 4585 and I have noticed that every one week or so the router will degrade, specifically WAN will go down and router will become unresponsive. Wireless will also go down with an exclamation mark.
A power cycle will bring everything back to normal and will again last one week.
Should I try 8671?
Thanks
Dellboy
Should I try 8671?
Thanks
OK tried 8258 and 8671, both cannot detect internet connection at Quick Internet Setup wizard and I've tried choosing Singtel-Others as special requirements. I'm using Singtel 500Mbps fibre connection.
JK, please advice.
ASUS@SG
Suspended
ASUS RT-AC68U firmware version 3.0.0.4.378.8258
- Release Note -
Security fixes
- Updated OpenSSL library to 1.0.2d
- Fixed CSRF and XSS vulnerability.
New features
- [AiCloud] Show image EXIF info on image player
- [AiCloud] Auto rotate image on image player.
- [AiCloud] Files can be moved and copied.
- [AiCloud] Images can be uploaded to Picasa or Twitter.
- [AiCloud] Share link can be posted on Twitter, Plurk, weibo and QQ in AiCloud.
- [AiCloud] AiCloud can be used in AP/ media bridge mode.
- Added 3G/4G USB modem APN auto detection feature. In most cases, firmware can automatically find the ISP profile and establish link when 3G/4G dongle inserted to router.
- Added Android phone in USB modem/ USB Tethering --> Select USB device.
- Bandwidth Limiter in Adaptive QoS --> QoS. Let administrator easily limit specific client's upload/ download bandwidth
- Independent mac filter for main wireless network and guest network. Administrator can set white list for main wireless network to only allow trust client connect to main wireless network and share network to guest with guest network
- Modified the network map client status. When click the client icon, administrator can bind IP, change host name, change icon, block internet access or set time scheduling.
- Added client list view button on network map and help administrator easily monitor all client connection status.
- Added the question feedback in Administration -> Feedback
- Added new DDNS provider www.oray.com
Modifications
- Changed warning page style.
- Changed Cloud sync Dropbox URL encoding from UTF8 to BASE64.
- Added stateful server in IPv6
- Improved media server response time when new file added.
- Adjusted Adaptive QoS UI and easier to set top priority for gaming, media streaming or web surfing.
Bug fixes
- Fixed MAC clone abnormal issue
- Fixed cloud sync issues between router and ASUS webstorage.
- Fixed share link related issue to Android devices.
- Fixed web redirection issue when WAN IP conflicted.
- Fixed compatibility issues for IE8
- Fixed GUI related issues
- Fixed login issue when router’s IP is 10.x.x.x
- Fixed parental control-> time scheduling related issue.
- Fixed adaptive QoS device priority label dragging issue.
- Fixed network tool related issues.
- Fixed USB HDD issue when using time machine.
- Fixed network map UI issue when selected French.
- Fixed the saving issue in OpenVPN server -> content modification of keys & certification.
- Fixed dropdown UI offset issue at Parental control.
Download: http://dlcdnet.asus.com/pub/ASUS/wireless/RT-AC68U/FW_RT_AC68U_30043788258.zip
Dellboy
JK, please advice.
ASUS@SG, please advise on my query.
