if the hardware is a lemon, no firmware can fix it. you need to fix the hardware. in other words, change the model.
Quick come poison us!!!ASUS RT-AC88U TGIF teaser coming tomorrow![]()
The 2 x 5 GHz only useful if you have many 5 GHz devices running together.Logically ... User from Triband ... To this .... Is a down grade of lost of a Band ... Right ?
Triband of 2x 5Ghz helps a lot to load balance .
WTFast client allows you to utilize their WTFast private WAN network rather than going through your subscribed ISP designated routes to the various game servers to achieve better routes/lesser hops/lower latency.
ASUS designed their ASUS RT-AC88U for gamers and enthusiasts in mind, whereas the AC5300 are designed for those whom wanted to utilize 2x 5GHz for their WiFi devices and the smart connect feature.
So, the WTFast is meant for gamers la? But not available on 5300 ah?
Quick come poison us!!!![]()
Mind if I ask. Difference between 88 and 3100?Yes, WTFast will be not available on the ASUS RT-AC5300 as far as i know, unless ASUS TW decide otherwise which is very unlikely.
WTFast is only available on the ASUS RT-AC88U and ASUS RT-AC3100.
ASUS RT-AC88U is part of the new ASUS ROG 2015 Arsenal.
3012 ............
AC3100 don't have colorful antenna. Also, only 4 LAN Port instead of 8.Difference between ac88 and ac3100 la. LOL. Aren't they the same?
Can I ask .... With all the issue we get at AC87U ..... Is the a trade in offer for 87U to 88U like getting the 88U at 50% of the cost ?
Fair for those 87U group also ...
