renfred89
- Nov 11, 2007
Guys, off topic, cut from microsim to nano sim will affects the sim? Or shld i get a real nano sim from telco? Hmmm
Sent from the dark side of the moon using GAGT
microsim to nanosim has a higher chance of damaging the sim card due to the size. you might want to get some good quality cutter to do the job, cos if the cutter is blunt, you might just damage the golden connector as a result..
i cut my microsim to nano sim with the help of a friend.. saving me a lot of trouble since i'm using nfc sim from the start..
