can i remove my chipset and change to a newer mobo
dissect
hi guys ...im currently using a prebuilt acer predator 5910
its coming to its 5th yr..
intel core i7-2600 cpu @3.4ghz
16gb ddr3 (from cpu-z it states 667mhz)
1tb hdd
nvidia gforce 545
i dunno wad psu rating i have..
well straight to the point....im thinking on getting a new pc for my new place..
but i was thinking of salvaging some of my current comp parts.
is it possible for me to reususe the i7-2600?
i was thinking of kping the hdd and chipset..if possible the psu as well
just get a new mobo, gpu and 8gb of new ram...if budget permits an ssd as well..
am i doing this rong.? pls advise
Goodshot
Of cus u can, just find the same gen motherboard will do
dissect
oh cause my current mobo no usb 3
and seriously the gpu not dat gd....i play on mid/low most of the time...
i was thinking if i just do mobo upgrade i can extend the life span of my pc
thanks for the input...i will try to scour for the appropriate items
If that's the case you will need to change casing change PSU change gpu.
As for usb3 you can get a pcie usb3 addon card.
Changing mobo won't extend lifespan of your pc cos your cpu might also go anytime.
jarred1223
you can reuse your processor, mobo, ram and hdd
just change your casing, graphics card, power supply.. and if you want you can add an SSD too
what games you play? also how much budget you have?
if you want change mobo to one that has usb3, quite troublesome as you need to reactivate your OS. your OS is tied to your mobo chipset
dissect
thanks for the heads up....
ive been looking up price list it seems my 1155 socket mobo quite scarce...maybe i shd rethink it over..
btw,,,i was thinking 500 bucks give or take another 100 bux for budget
my current games are bf4 d3 hots...but looking at the newer games soon....
mickykj
Some of the prebuild is non standard screw make sure to check it first before buy
This one need to take note.
You change mobo will mostly need to reinstall os and drivers and your oem windows microsoft might not let you re-activate.
MoneyFace =p
MoneyFace brand.
His cpu boh warranty liao and more than 3 years old even if he change mobo but if one day cpu spoil he also llst.
Dey processor is a high-precision engineered product. Your 10-15yo PC parts can go cui on any part but not the processor.
They are not like your RAM nor PSU. :s22:
MoneyFace =p
Reuse your CPU, RAM, HDD as secondary storage and chassis.
Please run memtest on your Acer PC to test your RAM for any error.
As for Windows, you can make use of the Windows product key from the COA sticker affixed on your Acer chassis.
MB: ASRock B75M-DGS @ $105 (nf2)
GPU: Zotac GTX 960 2GB Twin Fan @ $274+3*
SSD: Transcend SSD370S 256GB @ $110+3^
PSU: FSP Hexa+ 550W [80 Plus] @ $59+3`
Buy others from Lazada Singapore. Haggle for discounts!
All Lazada prices inclusive of delivery charge
*Price after Lazada App MasterCard Monday 10% off max $25 discount
^Price after Lazada App SINGLAZ15 15% off max $20 discount
`Price after Lazada App AAPROMO $15 off min $50 promo code
zzzzzzz
buy new graphics card and psu can liao
casing no need change if the card can fit in
as for usb 3, buy a PCIE card with usb 3.0 headers and buy a 5.25 inch or 3.5 inch usb 3.0 front panel to fix on the pc case if reusing old pc case
jarred1223
He just need to obtain a copy of Windows 7 OEM ISO for installation and enter that product key in. Done quite a few times le.
Isn't his cd key tied to the Acer motherboard? If he wants to change motherboard he needs to call Microsoft to reactivate?
MoneyFace =p
PC manufacturers activate Windows differently from standalone OEM/retail channels. They are provided with master key issued by Microsoft on contract to install on all their PCs, with additional data installed inside their PC BIOSes to recognise the PC manufacturer and Windows edition eligible to be activated. And up to Windows 7, PC manufacturers also affixed separate COA sticker with another product key on all their PCs for you to reinstall.
That is to say, the product key found on the COA sticker on a specific set of PC is not the one used to activate the Windows preinstalled on that PC.
