Sorry guys, but no matter what AC87U firmware (Merlin, AsusWRT Betas and Official, even HGG) I've tried, and even after factory resetting my iPhone, the 5GHz network is still bad. I am getting >2000ms pings and packets drops, and it's frustrating to have to fall back on the 2.4GHz network. So I'm going to put my router up to trade with an AC68U since that doesn't have a QTN chip. I hate this router to the extent that I'll do it with no need for a top up. Of course Asus won't care if I'm dissatisfied, they've already got my money.
U tried rma for another router already also the same? Thanks for the heads up will avoid this router like the plague
I know I should probably RMA it before writing it off, but I really don't have to time to go down to their service centre and deal with the downtime while they try to "diagnose the issue" all that. I got this router in September 2015 and it has been nothing but like that since day one. I just want my network to work.
Get the 88u or the 5300, I switched to the 88u from the 87 and it works beautifully.
Theoretical max speed for 5300Noted. How does the 5300 differ from 3200 ah? Same triband just higher speeds?
Or if on budget just get second hand ac68u with Warranty also good hor
Just turn off your 5GHz beamforming and you're good to go, no need to write it off lah.
Already tried with beamforming turned off and with a laptop cooler to cool it. No dice.
Did you select 'forget this network' your iPhone (5GHz) after installing the new firmware?
Yes I did. I even reset all contents and settings and set it up as a new phone. I also downgraded down from 9.3 beta to 9.2.1.
My family have iPhone 6 Plus, 6S, iPad Pro, iPad Mini (all 9.2.1) & Galaxy S6 all on AC87U 5GHz (Merlin 378.56_2) without any issue.
Other than your iPhone, did you tried other devices on 5GHz, any problem?
Question, does 5ghz work properly on ANY of the stock firmware?
Can ask for refund? From Asus SG? I think many ppl wants to ask for refund if it can be done.Finally, after 10 months of struggle I have sent the router back and got a refund. It was a wild ride! I suppose I am not patient enough or was petiant for wey too long!Considering to replace it with 88u or 5300! Any suggestions guys? I just want to feel stable, no thrills, no feeling like a testing monkey in a vicious circle of relentless firmwere updates.
