DSLR or Mirrorless (i.e. Micro 4/3)
shinnystarx
Hi everyone. I am thinking of investing in a camera. However, I'm not sure if I should get a DSLR or mirrorless camera.
I will be using the camera mostly for my travelling. I will also be recording some videos for memories keepsake.
For DSLR, I'm looking at Nikon D5500 and Canon D70. For, mirrorless, I don have one in mind yet.
My budget is around 1.5K (of course the lower the better).
Can anyone advise me on whether I should get a DSLR or mirrorless camera and which model would you recommend?
Thanks a lot in advance!!
Sauron
mirrorless can be aps-c right? not necessarily micro 4/3
cpuer
Sony A6000 will fit your requirement.
If you can live with fixed lens, the new Fuji X70 is good too.
EJB
Invest in the lenses, not the camera. Camera only handheld gratification. It's the lenses that will stick with you through the years while you change countless of cameras.
See which brand of lenses you like, the variety, the ease of 2nd hand, resale, etc, and decide.
N3wXTyp3
FujiFilm X-T10 but their video capability is meh...
DSLR is too big and heavy, I believe you might want to leave it at home when the weight and size gets to you!.
chikon
a6000 best bang for bucks for anything less than 1000$, can buy a good prime lens on top of it :s12::s12:
loveaddict
i was deciding between dslr and mirrorless, mainly to take photos when travelling and did not regret getting my a6000. honestly found it slightly troublesome already despite its lightweight body, especially when shopping etc, and felt damn relief that i didnt choose to get a 70d.
alamakazim
try the autofocus... and the viewfinder... on the mirrorless
if you are comfortable, get mirrorless
N3wXTyp3
I am not a Sony user but 1/2 a year ago.
I was deciding between DSLR and Mirror-less.
I picked the latter, they are light smaller and you see what you get.
I am OVF person but after looking at X-T1. I am quite sold to EVF...
Did I regret? nah. X-T1 the AF improved as we using get firmware updates and what best, another FW update will improve this camera again before the next model will be release.
The new X-Pro 2 AF is so good.... so DSLR are aging gems....
but we cannot denied the D5 and D500 from Nikon LOL
alamakazim
indeed... is getting better ... but only for the highend top of the line model
get a cheaper dslr on par with it, with extra money for lens
is always the same with everything... got the money... u will be rewarded
Anything_Whatever
I renewed my hobby interest with a mirror less 4/3rd Olympus but still find it heavy for my holiday traveling needs, even though with the few lens in the camera bag.
Lately for my travel needs, I now only go with my trusted GoPro Hero4 Black and my iPhone6plus.... Very good combo.
jenn.hart
Hi. You might wish to consider Olympus Pen series. I have been using them, and they are handy in size. Many affordable lens to choose from too.
sadboy
Last Dec I was looking for a mirrorless camera for my holiday.
I check out Sony, Canon, Olympus and Panasonic.
Sony: Great function but the size and lens just don't fit each other. Lens always bigger then body size.
Canon: Limited lens for mirrorless model and lens issue like Sony.
Panasonic GF-7 / GM5 : Both models are small and portable. if you looking for a camera just with minimum setting (more like point and shoot with SLR image) this would be the two model which you are look into.
Olympus E-PL7: Body are slightly bigger then Panasonic GF7/GM1. But the camera menu is easy to access when you attempt make any setting or change.
hawthorne
Panasonic and Olympus uses 4/3 sensors. Sony uses APS-C or FF (depending on model). Canon is APS-C
Hence, ur comparison is not apple to apple.
APS-C/FF sensor are larger. Law of optics needs to be obeyed, so larger sensor equates to larger lens. Larger sensors equates to better image quality or low light performance. Sadly, it also equates to a larger lens.
So, u need to first understand what is ur priority first. if size is a major concern and u r not going to invest in lenses, then I would go for a high end PnS (like the RX100). No point spending alot of $$ on a camera which u will not want to bring out. Also dun spend too little $$ on a camera which is so limiting that u dun like to use it
I'm a sony A6000 user and on lazy days, I would pick up my wife's RX100 instead. I'm using the 18-105F4 most of the time and I admit i find it too bulky sometimes. still i will make effort to bring it out
Jeremy1
I had a Nex 7 and a D4.
If you are looking at something portable, then forget about DSLR and go for a mirrorless camera.
If you need the focusing speed, then go for a DSLR but doubt you will need it unless you are shooting something fast moving.
You can considered even a fix len mirrorless compact camera if you are fine with fixed lens which make it very convenient and portable to move about.
hawthorne
Fixed lens camera (e.g. Sony RX1R) are for a niche group of people IMHO. If TS need to ask the question dslr or mirrorless, then a fixed lens mirrorless is definitely for him/her
sadboy
Yah I agree with you my compare it not apple to apple. My compare is just simple end user getting a camera. Like buying handbag.
To my wife, Camera is camera.. Don't care 4/3, FF and APC.
Thanks for adding this point in
Ah_keong
I have a EPL-3 (Olympus) and 7D (Canon).
For travel, I would recommend a OM-D E-M10 mark II for stills and maybe a Go-Pro. It fits your budget and should have some left for basic accessories. :D
allanlai86
Hi i have a following set to going to a new home, please contact me if anyone keen.
Olympus em5 body its like new, shutter count 1000, yes 1000 only, no user mark, no dent, no scratch or whatsoever, comes with full set inclusive of leather case, batt and charger, unused strap. usb lead and retail box.
there are 2x micro four third ens is as below, 12-50mm kit lens, as new condition with uv filter.
sigma 19mm 2.8 lens as new condition comes with uv filter.
four third lens are olympus 8mm fish eye 1:3.5 as new condition with box.
sigma 18-50 1:2.8 very sharp lens comes with hood and box as new.
olympus 40-150mm 3.5-4.5 comes with hood and box
olympus 70-300mm 4-5.6 super zoom lens comes with hood
nikon 55mm 1:3,5 macro lens manual focus (need adapter)
olympus mmf-1 original adapter as new
all the above item are in very good condition well sitting in dry cabi while not used, and working 100% as they shoud, testing are welcome, would prefer to sell as a lot. testing are welcome at novena please sms or whatsapp to eight four five nine zero 1 zero 1 to deal
