Vespula(!)
Pls advice on the frequent disconnection of 5Ghz wireless. It just show no data when i check on the status. My 2.4Ghz and wired connection still works.
renfred89
normal to experience that. cos its quantenna what. haha :D
Gymrat76
It's a common problem with this model. Log into the router and "rebooting" should solve it temporarily. The latest firmware allows you to set "reboot" times - though i have mine 2x/week at 3am, I still encounter a disconnection of my 5GHz about every other week or so. Totally disappointing that Asus is not doing anything to address this longstanding issue.
Besides this, I've also encountered frequent downtime for the 2.4GHz and wired connections, until I turn the router off and on. This even with a cooling pad (which debunks the myth that it's a cooling issue). It simply is a poor product from Asus. Will save up and get a Netgear soon.
DriftKing
Hi guys, can I have a quick check, currently im on PCE-68 + RT-87, if I click on Wifi on windows 8, view connection settings, click on my connected wifi, the Protocol is showing me 802.11n instead of AC, I'm connected to the 5Ghz band and I'm worried that I'm still getting N speed for some reason, how else can I check if I'm really on AC speed currently?
renfred89
go to your ac87u wireless log and see?
if not, look at the connected link rate. pce-ac68 is capable up to 1300 on wireless ac, if u don't reach anywhere near despite within a reasonable distance, then confirm u no on wireless ac lor..
xsoldix
What if ....
Your wireless AC is connected via usb 2.0
480mbps bottle neck
DriftKing
It is a PCI-E Slot card -> PCE-68, so its not bottleneck by bandwidth (I hope).
The PCE-68's wireless monitor for some reason after an update it doesnt show me what speed it is connected to.
renfred89
can show us a screenshot?
i remember it will show up somewhere like you said, not sure of the new update though..
poor_poor
DriftKing,
802.11ac is only recognized by windows 8.1 (NOT windows 8)
Could you share with us your Windows build and router 5Ghz configure settings.
jskywalker
I'm using a Asus RT AC66U now and wanted to buy a 2nd hand Asus RT AC87U for a upgrade.
I heard and read about the infamous 5G Wifi issues.
Is it solved ?
Should I change my router ?
poor_poor
Is it solved ?
If you want to upgrade then i suggest you get any of these three router: RT-AC88U, RT-AC5300 and RT-AC68U.
The Asus RT-AC87U have lot of issue on wireless, unless you are using MU-MIMO beta build firmware that i have posted earlier than the 5Ghz will be stable.
Gymrat76
Is it solved ?
Stay away from this router. Experienced disconnection 2x today, had to turn the router off and on.. this despite rebooting it twice a week and adding a cooling pad. Crap product.
wlcling
help
hi guys, need help before i throw my asus products down the building.
i'm using the ac87u (merlin fw) and started facing connectivity issues recently to the 2.4ghz network (i rely on 2.4ghz network bcos 5ghz range seems to suck so bad). Check out these results below
2.4ghz (client device far from router)
a) iphone 6s (signal/ping/download/upload = 3outof3bars/2ms/80Mbps/30Mbps)
b) Desktop with asus pce-ac68 (signal/ping/download/upload = SSID appears & disappears randomly. When 2.4ghz channel appears, can't connect. Only 5ghz SSID is stable)
5ghz (client device far from router)
a) iphone 6s (signal/ping/download/upload = 2outof3bars/4ms/35Mbps/30Mbps)
b) Desktop with asus pce-ac68 (signal/ping/download/upload = 4outof5bars/4ms/1Mbps/1Mbps)
*speedtest results are from speedtest Viewqwest server. (my broadband = 1gbps Viewqwest)
Is there something wrong with my asus pce-ac68? (i've downloaded latest drivers) furthermore i can't connect to router homepage from my desktop! (blank white page). From my iphone however can and the speed also so much better...
Gymrat76
Can you repost the link to the beta firmware please? This thread is getting too long to search through
poor_poor
RT-AC87U MU-MIMO Beta firmware Build: 3.0.0.4_380_1393
Download: Click here
- After updating the firmware and you are required to restore to factory default settings.
5Ghz Professional Tabs
- Enable Universal Beamforming
- Enable MU-MIMO
Bug:
- Traffic Analyzer
Reboot the router.
Gymrat76
- Enable Explicit Beamforming
- Enable MU-MIMO
Reboot the router.
Thanks, will give this a try (last resort)
Gymrat76
With beamforming on now, the 5G is much better. I used to have trouble getting signal on my 2.4GHz band in the kitchen area, but with BF on, I can get 1-2 bars of the 5G even.
WIll monitor and see if the outages to the 5GHz recur. Thanks poor_poor.
dodongdodong
- Enable MU-MIMO
Reboot the router.
may I ask where can I find the explicit beamforming?
