deodorant
- Jun 4, 2011
Ropeway is closed for now cos of volcano btwropeway
If I stay in Shinjuku, you guys think is possible for me to leave early and get a hakone day pass to take cruise, ropeway, cable car, see mount fuji from far, enjoy onsen and head back home to shinjuku at evening time?
Sent from mobile using GAGT
Still deciding to do day trip or two days one night at hakone.possible. But you wont be "on the ground" much of the time, as in you will be moving from one transport mode to another.
I just returned from Japan. The temp is about 8 to 10 degree in day time and at 5 degree at night. Probably it is even colder while we are sleeping.
5 degree vs 15 degree is lot of difference. For me I don't think the 1st top piece can actually keep me warm at 5 degree.
I wear 3 layers. Base Layer is heat tech, followed by a long sleeves and outer is the light weight uniqio down jacket. especially with chill wind blowing, I wear a beanie. It made lot of difference when your head and ears are covered.
So 15 degree need to wear how many layer?
I'm going in March, should be around same temp?
Depends on your own tolerance. For me, 20deg I just wear t shirt plus casual jacket/blazer. 15deg no wind no rain, long sleeve tee plus casual jacket/blazer. Lower than that then only will consider heattech, scarf, etc.So 15 degree need to wear how many layer?
I went to Tokyo in early March before and it was still below 10 degree. Anyway u can always buy the winter clothes there if not enough to keep u warm. The winter clothes are cheaper there.
Just wondering , once you get indoors, what will be the temperature like? I guess no need wear jacket once indoor right ?
Most of them like shoppers or passers-by will still wear their winter clothing rather than doing change parade. Only those staffs who worked indoor wear normally.
I don't see ppl carrying the winter jacket around the moment they step into indoor. Even on subway train too. Unless your ride is long ride.
So even indoors will feel cold?
Wanna check regarding hyperdia..
I tried searching for journey from odawara to Narita T1. I saw there is a fare 3,020 plus seat fee 3550. Is the seat fee referring to the reservation for seats?
Taking shinkansen from odawara to shinagawa.. Then NEX to Narita.
I tried editing but seems like NEX must reserve seats?
Anyone know what does the label says?
TIA
seems like best before feb 13
just a small correction... it means around, not before
seat fee is the additional charge for limited express and shinkansen. there is a seat fee regardless whether it is reserved or unreserved seat, with unreserved seat having a lower seat fee
NEX only have reserved seats iirc
