iPhone 13 Series
xBlackHawkx
The main rumours would be 120hz, on-screen ultrasonic touch-id and smaller/cut out camera notch. Rest would likely be slight incremental improvement.
edmwperson
hopefully touch id and face id can come together, we choose what's easy for the user
arcturuz
Touch ID would be great again when we are all face mask at least for another few more years
ragnarok95
Senior Moderator
Senior Moderator
I do not think the notch will be smaller. The next time there is a change in notch size, it will be.... Apple have completely remove the notch. It's either you have it, or you don't.
I think biggest change this yr will be the display, and Apple focusing on ultra wide angle lens.
StraightShooter
-120 hz
-Under the screen touch id
-Smaller or no notch
-Bigger battery
-More RAM
-Split-screen multi tasking for bigger screen iphone
My wish list above.
ragnarok95
Senior Moderator
Senior Moderator
Iphone won't go USB-C because lighting port is bringing in money for them.
