2013 MBA wifi issues
netzach
can try in the store now with ur phone's hotspot WIFI....check if the displayed is a 2013 mid model first....
:o
Thank kiew for the tip bro Op_V!
Gonna try that out soon. HEHEHEHEHEHEGEHEHEHEHE
All well for your MBA mah so far?
Op_Valkyrie
No problem bro, So far no issue yet ...
i'm on OS X Mavericks DP 2 now...WIFI still looking good
:o
donald83
when u guys upgrade from an old imac/macbook to a new one, what do you do with the old one?
I am still using a 2008 version of iMac and very tempted to get a new one but my current one still works fine, just abit laggy
squeeish
You sell it.
alpc
Have been using it for 2 days... Nothing wrong with wifi yet. Have not even got time to read about what was the issue with wifi! Ha Ha!
Op_Valkyrie
I tried test out my WiFi Speed last nite at 802.11n 5.0ghz - hit 5mbps....constantly no dropping
fuzzybear
battey so good but how ia the performance ah ? im itchy too now using a 2011 mbp
fuzzybear
but u can't customized if I go epicentre right ?
but having 8 gb will it improved much on performance?
im now on mbp 8gb over all ok
but mine is a 2011. set
Op_Valkyrie
i think more better than less.... cos its non user upgradeable but that may not be penny wise for certain ppl.
else 4gb should suffice for most case...
netzach
Can't customize in epicenter
Op_Valkyrie
can customize....
If they got extra CTO that they ordered and match ur CTO specs
or
U customize CTO specs they ask u come collect another day as they will order from apple directly the CTO - some ppl like foreigner or no credit card use this method
