2018 iPad Pro
luckygal
Third party Apple Pencil would just be a normal stylus and not have the all the functions right
BoeingWong
Except to get cellular Data for using this IPad when no WiFi, basically no other advantage for getting cellular version right?
*adiBOY
Absolutely not. Like any Apple new invention, the magnetic holder and charger will only be compatible to the Apple Pencil
Anyway, do any of the retailers have the pencil and smart folio in stock?
BoeingWong
adiBOY, about the AppleCare, better to have it??i always buy it with my iPhone but this is my first ever IPad, does it require you think?
And I think I won’t be changing this iPad like the way I change my iPhone, 256 good enough?
Yup that will be a wiser choice unless cellular is a must for you.
quiksive
Looking for temper glass now
luckygal
Dunno. I need to check with my nephew. I am not IT savvy or fan of Apple
*adiBOY
For iPad I would recommend getting AppleCare+. You’ll never know what issue will surface with that level of thinness or you might just drop it accidentally.
quiksive
Ipad Apple care 189 dollar I think quite worth it. Anyway you got 60 days to consider.
Errz
Size compare
12.9 inch is heavier... and not really that comfortable to hold with one hand.
With keyboard attach, both model feel soooooo heavy.
12.9 with larger screensize does looks nicer ....so if weight, size and $$ is not an issue, go for the bigger size.
