2018 iPad Pro
Heypipi
Anyone knows if the education pricing applies to apple store pickup or any apple retailers stores?
xhui22
From what I know you can order online Apple store and you can also choose to pick up at Apple store Orchard. Not those retailers.
Maximus_XXVIII
Hi guys, need some help as I'm not familiar with Apple products.
- I have a Aukey Quick Charge 3.0 wall charger which is rated up to 18W of output, will QC 3.0 work on IPP or will it just charge at normal speed?
- Can I transfer files from Window's computer to IPP directly (Like how we transfer files from Windows computer to an external HDD) or do I need to go thru iTunes and other software?
manofsorrows
With ios im not sure if drag and drop would still work.
*adiBOY
- iPad Pro does not support QC3.0 however, it does support fast charging through USB-C PD. Which means to say, unless your Aukey wall charger comes with USB-C PD, it will only charge at 2.4a through USB-A.
- You cannot transfer files from Windows to iPad Pro directly through the USB-C port. You may want to use iCloud to transfer the files to your iPad Pro.
*adiBOY
anyone feel that this 2018 ipad design is similar to ipad very first gen?
They certainly do take some cue from the very first iPad. I wish the next iPhone will be of similar design language to the new iPad Pro but I very much doubt so due to the glass back :(
tokyofanboi
I read somewhere is better to have 30w portable battery. And which anker portable battery should work best for iPad Pro?
rvyne7
I'm using my MBP 87w charger for both my iPhone and new IPP .... :p 30w still not fast I think
saggice
memory size is really up to individual.
for me i use online streaming so only need very small memory size
