2018 iPad Pro
xhui22
Anyone can share how’s the Apple keyboard? Trying to justify to myself to get it over waiting for the 3rd party ones. Sorry if I sound noob cuz am upgrading from an Air 2 (dinosaur). Thanks!
spunkbrat
Earlier, I tried to charge my 11” with my Anker desktop charger USB port rated at 2.4A, with a USB C adapted fitted to the micro USB cable, it failed to charge.
Then, I use my XiaoMi charger with its USB C cable, it failed to charge too.
Makes me wonder if the new Pros are intelligent to only allow chargin with its original iPad Pro charger and cable?
Anyone else charge their Pros with 3rd party charger/cable successfully?
Does Apple have their authentication chip on the USB-C cables as well?
tohchr
Quite a good buy. When u flip all the way to the back to hold the ipad with one hand, of course u will press the keyboard but it will not trigger anything. Very strong magnet to hold the ipad and the keyboard folio case together. No regret and I’m using it to reply to u now.
xhui22
Nice. I went to play with it in store and it’s very light! Though the orientation of the ipad took a while for me figure how to move it around. Hmm. If it’s for 4-5years investment, maybe can stick to this. 🤣 thanks for sharing!
tohchr
I’m also using 3rd party charger and Samsung type C cable, no issue. My original ipad cable and charger still inside box.
tohchr
Best is u need not turn on Bluetooth for it to work. No need charging as well.. I wonder how this thing connect and work but I think the power came from ipad as it had 3 gold colour connectors at the back.
xhui22
Haha you just sealed the deal for me! Thanks for sharing again. :)
xhui22
Another noob qns. Does anyone charge their ipad from a USB port (those multi USB port charger adapter)? Means the cable is USB A to USB C (ipad)? Too many devices to charge. IPhone XS, iPhone 6, and IPP. Hope no need bring so many charger out
tohchr
I’m using the above mentioned hub to charge my ipad, iphone, Apple Watch, note 9, p20 pro.
tohchr
you guys purchased the wifi or wifi + cellular model?
I got the 11” Grey Cellular 1TB model. I need to use it on the go most of the time to access work related stuffs. Download cctv videos, definitely need 1TB space.
*adiBOY
Connect and powered from the 3-pin smart connector at the back.
*adiBOY
Might need to enable the USB accessories inside the Face ID menu.
xhui22
Anyone purchased your ipp under education discount? Is ID verification needed at store?
