2018 iPad Pro
obichacha
Wow, thanks a lot.
Hi, here it is.
cloud77
There are 2 from Anker:
Older model:
https://www.amazon.com/Anker-Charge...qid=1542450685&sr=8-6&keywords=anker+usb+c+pd
Newer model:
https://www.amazon.com/Charger-Anke...qid=1542450685&sr=8-3&keywords=anker+usb+c+pd
Good thing about the older model is that the USB-C PD can draw more wattage as claimed due to some IC bug.
thks so much ! saw this, https://www.lazada.sg/products/anke...o42.searchlist.list.3.797b559c9bmUuI&search=1 ?
Anyone did a comparison between the charging speed of USB C PD vs normal USB C - USB A cable ? I am using a normal USB C - USB A cable for now and it took quite a while to charge my ipad pro 12, i was wondering if the difference is significant for me to take the plunge and go PD with a separate charger
cloud77
anyone upgrade from the old ipad 12.9 to the new ipad pro 12.9? does it make sense to do so and was the difference worth it?
i have both the new and old ipad pro 12.9 and was using the pro 10.5 as my main device previously. I feel there is a big difference, eps the size and weight. The old ipad pro is really too heavy n big to bring around anywhere.
The new ipad pro 12 look really good with a lot of "screen size" and is small and light enough to be used as a main tablet to replace my 10.5, face ID rocks too !
htngwilliam
I used the gen 1 12.9 and the 10.5 but still like the gen 3 12.9. It is smaller and lighter. Also easy to use as it is smaller than MacBook Pro and much lighter. I think probably this will be my favourite device.
I have been thinking the new 11” or 12.9”? I decided 12.9” because I think I will use it more on the desk than on the go. The 12.9” split screen is also amazing. Haha
Richnogo
Writing
This one can use tablet pens on it and make comments on things like pdf?
didymus
Should I get the 11" or 12.9"? Mostly use at home viewing movies/surfing web/etc... have mbp ...
toshiro_sg
if u are not into drawing and only media consumption, 11 inch really the sweetspot in terms of cost and portability. 11inch actually pretty big already.
iguoh
11 for cost and portability. 12.9 for experience. I went for the 12.9 as my last iPad was a mini (first version).
Posted from PCWX using Pixel 2 XL
iguoh
I was at sls yesterday. Saw the nubox on ground floor got 12.9" folio keyboard case.
Sent from Google PIXEL 2 XL using GAGT
I just called. It is OOS there as well, same at Nubox Raffles Citiy. Even Apple store online is stating a 7-10 day delivery. I guess I will just have to wait.
JAson1980
Apple new iPad Pros bend easily.
Better becareful where you place it
wow, its not unibody. literally like top and bottom frame sandwiched between the glass and back cover. :s22:
higher chances of bending it if really not careful compared to other Ipad models.
Glariel
Feel like making me want to get folio keyboard so that it won’t get bent easily.
Finally found a reason to hold back and not to buy the keyboard cover for my current 10.5
htngwilliam
To be very honest, the only time to get 11” is when u need portability (mainly if u use it in a packed train etc). Apart from that, 12.9” works better. If you can use A4 size writing pad, I think 12.9” iPad Pro is almost same size. Awesome for multimedia/ movies. My wife like the 12.9” iPad Pro more than the MacBook Pro as she use it for some notes, reading and multimedia.
saggice
Thanks for the feedback bro! .... but do agree that 12.9 is a bit huge to watch some videos in train cos the screen super big, but I do like big screens too, more shiok!!
yes no idea why but the old 12.9 is really heavy !!!
audioenslave
Nobody in the right frame of mind will bend their ipad pro unless they got lots of cash to throw around.
Juz get a folio case frm apple which i did, throw into my bag pack and everything will be fine..
