2018 iPad Pro
htngwilliam
Thanks for the feedback bro! .... but do agree that 12.9 is a bit huge to watch some videos in train cos the screen super big, but I do like big screens too, more shiok!!
yes no idea why but the old 12.9 is really heavy !!!
If u r using in train, 11” is the way to go
*adiBOY
thks so much ! saw this, https://www.lazada.sg/products/anke...o42.searchlist.list.3.797b559c9bmUuI&search=1 ?
Anyone did a comparison between the charging speed of USB C PD vs normal USB C - USB A cable ? I am using a normal USB C - USB A cable for now and it took quite a while to charge my ipad pro 12, i was wondering if the difference is significant for me to take the plunge and go PD with a separate charger
There is a lot of difference charging with USB-C without PD and USB-C with PD. You’ll see about 30-50% difference in the charging speed.
obichacha
Get xiaomi 45W or 65W PD comes with type C cable as well.
Cheap and good
*adiBOY
Feel like making me want to get folio keyboard so that it won’t get bent easily.
Finally found a reason to hold back and not to buy the keyboard cover for my current 10.5
Your comment always make me LOL.
In fact, you’ll have more issue with your fingers covering the Face ID than the new iPad Pro bending easily. Don’t make it such a big issue when it is almost a non-starter.
*adiBOY
obichacha
The price not much difference between 45W and 65W.
Of course 45W is sufficient for all, even Macbook air or Mbp 13
I have many PD haha
Yup but I am specifically mentioning about the using the 65W on the usual suspects not the laptop category
xtwis7
Will see if it works well. I read some reviews that’s why I went with this brand. Not easy to find good braided cables from established Brands
Becareful since they are not MFi certified.
*adiBOY
I have many PD haha
The next one you should buy from Anker. Probably the best charging brand by a long stretch!
*adiBOY
But Anker seller overpriced 🤣🤣
Alternative with Aukey is better
That is because you are looking at Singapore market!
You should only buy Anker from Amazon. Superb customer service too. Replace faulty items bought without question and no need to return.
obichacha
Amazon return postage can consider to buy half of new PD from aliexpress.
Anker don't have what I want.
I am prefer 45W or 65W type C PD, so far xiaomi 65W PD still the best.
This is fast enough to charged for iphone XS MAX.
The rest is slower to me.
*adiBOY
Anker does have 45W and 60W USB-C charger and you don't have to return if you face any issue. Anker will just send you the replacement FoC (you can ask for a replacement even if there is no problem lol).
Anyway for iPhone and iPad, the max they can take is only up tp 30W. So buying a 45W or 60W USB-C PD power adapter will not speed up the charging speed unless you are also using the adapter for your USB-C powered laptops.
