2018 iPad Pro
swgj86
Yeah. I was contemplating for quite some time. It initially went oos for a few days and then stocks came in again.
Should check from time to time. Maybe will have.
Lucky you. Hard to find deals for 12.9, always seems to run out. There was the 256 12.9 for $1099 as well.
CeSaRiO
For those who are looking to get the iPad Pro 2018 model, Challenger only has the 512gb wifi cellular for 1299. I’ve just bought one today.
One key advice will be to get CapitaLand Vouchers at about 4.5% - 5% off and buy the ipad. Save you about 64 dollars to buy something u want.
Zubuto
I managed to get the 64gb wifi only version from Apple Sg (refurbished) 2 days ago at $819 and it was delivered today.
Andykaka
Signed up for hachi yesterday and went to challengers to hoot ipad pro 2028 12.9 inch /512gb at $1299.
xxSaDanxx
Morning all.. looking to get 2018 iPad Pro 12.9, cellula model. If spotted any Challengers still having stocks and sales can help update here?
Thank you! And also, can advise where is the best place to get apple care plus and the pencil?
nangongjun
How many of you are using it with the magic keyboard?
so used to the macbook’s trackpad and magic trackpad, the much smaller trackpad on the ipad floating magic keyboard just dont feel as spacious and comfortable when navigating.
pro is that it has backlit n able to charge while using external storage
look at the difference in size
hmsweethm
Using with Apple magic keyboard 2018, together with Uag scout cover.
It’s the only cover that u can use with existing magic kb 2018.
There’s a casing cum kB called brydge kB.
https://www.brydge.com/products/brydge-pro-plus-for-ipad-pro
But after reading the reviews, its reliability seems to be questionable and will crack your ipad glass.
But the design is really awesome.
szeli
have u all checked out this? trackpad hidden under e keyboard, getting funded soon
junk610
Was told by a Challenger salesperson that the 2018 iPad Pro 11" 256GB was on promotion at Challenger for about $500 recently. Find that a little hard to believe. Anybody know if that is true?
manofsorrows
I only know the 1tb cellular model is $1399.
tengg
Is Ipad Pro 11 inch (2018) a discontinued model? Usually how long does Apple support for firmware after announcement of discontinued?
It is not very different from 2020 iPad Pro. A12X is only slightly less powerful than A12Z, and the biggest difference is 4GB RAM and 6GB RAM.
Currently the 2015 iPad Pro is still supported, you can be sure that it will still be supported for a long time to come
babalusan
Anyone bought ipad pro 2018 from amazon usa before?
I have ipad 2018 version and looking to upgrade for the pro motion and usb c
The new ipad air doesn't have pro motion
Price wise is the same around sgd900?🤔
s0tong
900 is including 7% gst already? I thought I calculated, is about there.
But I do have a question for this thread. Is ipad region locked normally?
