2018 iPad Pro
lunarsong
Thank you RocketBunny for sharing your usage and thoughts.
Thank you Lunarsong for the detailed explanation. As for the portable HDD, is it possible to use the Seagate Backup Plus Portable Drives?
you can opt for either a wireless or wired. if you are thinking portability, you may even use thumbdrive if you need to transfer files between you and your colleagues, and then backup them in hdd when u reach home
but will need an adapter to connect your thumbdrive/hdd to your iPad pro though
staralliance
Thanks again for sharing. Currently, I'm using the Seagate Backup Plus for me MacBook Pro 13".
With all the inputs from all, I decided to get IPP 12.9" 128GB WiFi with Logitech Slim Folio Pro case and Apple Pencil Gen 2 which is within my set budget.
anthonygreenisreal
Is it worth it to get the 2018 iPad Pro 11 inch at $999 for 256gb model or the 2020 iPad Pro 11 inch 128gb model for $1199?
Snoweagle
If you want the latest and greatest, the choice is obvious. But do note the 2020 model’s upgrade is only subtle from the 2018 model. The A12Z processor is only slightly faster than the A12X with an extra GPU core. The 2020 model supports wifi 6 but you’ll need a wifi 6-capable router in order to utilise it. Lastly, an extra camera with LiDAR sensor for improved AR capabilities.
If you really need the LiDAR, wifi 6 and that slight power boost, then 2020 model is your choice, else everything else is the same as the 2018 model.
Now also comes cost to capacity. If money’s not a big issue to you, just get the latest model. $200 extra with 3 improved features (depends on your needs) but with half the capacity. If capacity matters a lot to you over those new features, I suggest the 2018 model ($200 less with double the capacity).
The ultimate choice is yours bro, the 2018 model is still a powerhouse and can last for at least another year or two. If I were in your shoes, I’d buy the 2020 model since I don’t use anything more than 64GB for iPad.
dingdung
All iPad Pro 2020 models also equip with 6gb RAM which allows more apps and tasks to run even more effortlessly.
anthonygreenisreal
Yeah I think the iPad Pro 2020 128gb is the better deal. Can find deals online for about 1149 which makes it only $150 more than the iPad Pro 2018 256gb.
For 2gb more ram, slightly better CPU and better graphics and camera/mic and wifi speed.
It’s makes a lot of sense to go for the iPad Pro 2020 despite lower capacity. Quite sure I won’t be using until 256gb of storage.
lunarsong
I bought the 2018 IPP 11” and spent the price diff between it and the 2020 IPP 11” on Apple Pencil.
Don’t rly need to LIDAR and WIFI 6, and no use for the extra 2GB ram. Unless you use graphic intensive app like Photoshop or Lumafusion
If you are student, price is $1129 on edu store for 2020 11" 128GB. Best to wait for back to school promo, they will give free Beats that you can sell for $100+.
micgoh
Was there a courts promotion etc? Saw carousell flooded with this model brand new in box.
anthonygreenisreal
Haaichi Tech and a lot of places are clearing the 2018 IPad Pro for a really good price as they are discountinued. These people on Carousell are mostly scalping to earn quick bucks from these online deals.
GreenTea97
Would anyone recommend the 2018 or 2020 model for a uni student? mainly looking to write notes only and tbh the few hundred or so i can save can be used for the apple pencil etc
anthonygreenisreal
If you wanna write note only can just get the iPad 2019 With Apple Pencil 1. It’s is a whole lot cheaper than even the iPad Air 3.
GreenTea97
Thanks for the suggestion! yeah it kinda makes sense to me to get the older model especially since i can save a few hundred dollars in the process, thinking of getting a refurbished model once it goes back in stock on the apple website to save even more
trenzterra
Only bugbear is that iPad 2019 has a non-laminated screen, so in between your pencil and the screen itself you will feel a slight "gap"
feigningfancy
Yeah if the deal is still around from hacchi tech with student promo is more worth it
