4K video playing problem
noobiee
lol all focusing on the cpu and gfx but never ask the 4k video in ssd or hdd
86technie
wa both cpu and gpu cmi? have to overhaul liao :(
if i had to choose 1 to upgrade only then would be cpu first i believe?
CPU is dated and will bottleneck RX580.
Upgrade CPU to Intel/Ryzen depending on your budget, GPU
at later stage.
FYI I still have a old AMD Phenom II X 940 with Geforce GTX560 graphics.
Full HD is the most it can handle but not 4K for that generation PC.
cheetz
hmm talking about upgrade, i'm also thinking between a qhd 144hz monitor vs 4k 60hz
i rarely play fps games, mostly mmo like wow or singleplayer adventure games. and quite often use my pc for watching tv/movies
rarely upgrade also, usually once every long while as perhaps u all can see :s13:
thanks guys
thanks guys looks like i will upgrade cpu liao
appreciate can advice regarding monitor also, thanks!
MeetYourTea
try go vlc tools under preference setting.
go to input/codec tab
choose DirectX Video Acceleration (DXVA) 2.0 under hardware-accelerated decoding.
