I take Xiaomi or TCL over prism anyway. Prism price is almost as high as TCL now, at least TCL make their own panels and not ODM, while xiaomi is the cheapest.prism+ 55" at $679 good price or have other recommendations?
Wah how you hoot $508? I eyeing Q2 on shopee now is $738 voucher -$58= $681. You get from shopee or Lazada?Managed to hoot 1 on 11.11 @$ 508.88 55" version
11.11 salesWah how you hoot $508? I eyeing Q2 on shopee now is $738 voucher -$58= $681. You get from shopee or Lazada?
Thanks for the recommendation, where do you usually shop for your TV? Should I buy from online store? or physical store ah?Perhaps the Sony X90K or X85L or TCL C745.
I normally buy online, especially now got Black Friday deals; but think even better prices can be obtained from the physical shops. If you got the time, go visit several shops and get the best price.Thanks for the recommendation, where do you usually shop for your TV? Should I buy from online store? or physical store ah?
Cool. I was down at Best Denki last week. Thought their deal was slightly than what they had online. Thanks for the recommendasi.I normally buy online, especially now got Black Friday deals; but think even better prices can be obtained from the physical shops. If you got the time, go visit several shops and get the best price.
Thanks for the reply. Now the Black friday on lazada is worse. $731 no voucher no laxada bonus can be used. Shopee better at $68111.11 sales
bank + lazbonus+shop voucher
Thoughts on TCL C845? They are going for $1774 with free subwoofer and soundbar.I normally buy online, especially now got Black Friday deals; but think even better prices can be obtained from the physical shops. If you got the time, go visit several shops and get the best price.
Definitely an even better TV than those I've suggested earlier. That said, I prefer Sony's image processing more, so I'll choose the X90L over the C845. But that's me. Also, TCL warranty support will not be as good as Sony's.Thoughts on TCL C845? They are going for $1774 with free subwoofer and soundbar.
Anyway, see what this highly-regarded reviewer says about the C845 and then make your decision.
CU7000 looks pretty similar to the AU7000, so since the later is good enough, so will the former.What's your recommendation if I go <= $1000? 65" ? CU7000 any good? My house has a Samsung AU7000K and it is pretty much good enough.
I have more faith in TCL image processing, so C645. No idea about app installation though.Hi everyone .
Between tcl c645 55 inch and
xiaomi Q2 65 inch
Which is better ?
And which 1 can
install 3rd party app ?
Thank you so much![]()
Is the TCL C845 worth it? I'm planning to mount a good 55" TV in my bedroom. Will be watching Netflix dramas/movies most of the time. Thanks.
For dramas/movies, I'd go for Sony X90L or even X95L, if I don't already have the $$$ for the A95L.Thanks. It seems to have a few significant deal breakers. Maybe I should consider others.
