5GbE and beyond ethernet adapters
sglandscape
Nothing to improve already. You already hit the limit of XGS-PON technology used by local ISPs for the 10Gbps plan (kind of fake 10Gbps, should really be called 8.5Gbps plan).
Next leap would be roll out of 25G PON then maybe 50G PON, but we are no where near where such speeds are affordable for home networking gear yet.
stanlawj
Just tested Wavlink's WL-NWU342G (AQC-113-B1), direct connection to M5 Max Thunderbolt port.
https://www.wavlink.com/en_us/product/WL-NWU342G-black.html
I ordered black from Wavlink Lazada, but it arrived silver inside the sealed box (outside the sealed box is black unit shown :unsure:).
The network adapter is rated as Thunderbolt 3 (which includes USB3.2 Gen 2x1 10Gbps only).
It is labelled as USB4 but doesn't support USB3.2 Gen 2x2 20Gbps.
[For that, you need the other Wavlink WL-NW343G (presumably uses the latest Realtek 10G chipset).
https://www.wavlink.com/en_us/product/WL-NWU343G-black.html ]
No driver required for MacOS (connected as Thunderbolt 3 device). However, driver must be downloaded from Wavlink support site for Window and Linux.
------Performance tests------
Speedtest through my ISP at 3am:
8 Gb/s down, 7.8 Gb/s up.
No jumbo frames.
Iperf3 between local machines: 9.17 Gbits/sec
Temperature-wise, the external heatsink appears to reach up to 40-ish deg C.
(no cooling assistance from external fan).
Room Temp is 30 deg C.
There are vents on the base, so I suspended the network adapter on an external PWM fan.
Much cooler temp achieved while a small external PWM fan is below it.
I stick to this setup to prolong life and as insurance against over-heating under heavy transfer loads, which is a known issue with all 10G USB network adapters (Realtek or AQC).
About AQC 10G chipsets:
AQC-100: SFP, old chipset before 2020, runs hot and draw a lot of power.
AQC-107: RJ45, old chipset before 2020, also runs hot and draws a lot of power.
AQC-113: RJ45, newest chipset from 2022, runs cooler and more efficient.
Do not buy older AQC chipsets.
https://www.marvell.com/content/dam...llers/marvell-fastLinq-edge-product-brief.pdf
Interesting comment about Realtek RTL8159 based USB 3.3 Gen 2*2 10Gbe adapter. The following post mentions about latency spike which is not good for gaming. Not so sure if other users facing the issue or not.
Just to update. I'm one of the early onr all in subscriber. For $85.11 before gst, I have the starhub entertainment pack, ethnic language pack, sports +, premier +, TV+ pro rental (which I seldom use these days) and Netflix premium plan. Also including the 10gbps broadband.
Contract ended in March this year. But like what Henry Ng mentioned earlier in this thread, there is no contract end date. For this price I suppose no isp can match
On hardware front, I bought the xikestor 10gbp USB nic based on realtek 8159. For downloading and general browsing it seems to be stable although it can increase cpu utilization when approaching faster speeds. However I find it not suitable for gaming as it causes the latency to spike to unplayable levels when playing poe
No issue when using native mobo 2.5gbps ethernet
stanlawj
Realtek drivers for new chipsets need some time to get improved and updated. Their 2.5Gbe USB network adapter also required some time for a stable driver.
Driver stability (in MacOS) and thermal performance under load are also some of the main reasons I chose AQC-113 over RTL8159.
shin89
Hooted a 10G LAN Card PCI e 3.0 X4, using Realtek 8127. Shipping on the way.
Hooted one as well, but regretted getting the rj45 version as it seems like its easier to utilize sfp+ on consumer routers, otherwise need to get another sfp to rj45 module which runs hot.
stanlawj
Just get the standalone 10G Media Converter box to convert between RJ45 and SFP.
Then use passive copper 10G SFP instead of active optical SFP since the distance is < 1m to keep the conversion between optical and copper to only once.
A separate standalone box will solve the heat issue.
The SFP-RJ45 converter module is essentially the same circuit as the Media converter, just miniaturized and heatsink sized down causing much higher temperature, risking thermal throttling. It's not worth the high price, after I discovered that much cheaper standalone 10G media converters exist.
shin89
Any good recommendations? I see these 10Gbe media convert boxes (rj45 to sfp+) all running almost $100 SGD. If got taobao link that will be much appreciated!
stanlawj
I'm using Horaco 10G POE+ fiber media converter. There is a cheaper non-POE version. You don't need the POE if you're converting the ISP's 10Gbe copper to your router's SFP+ port.
M1 10Gbps test results with older version of XikeStor USB4/TB4/TB3 10Gbe adpater under Windows 11. It is based on Marvell AQC107 chipset.
Test was done on 11-July-2026.
Windows laptop speed is less consistent (especially the upload speed) but pretty okay as well.
Acer Swift Go 14 2024 model, Windows 11
XikeStor USB4/TB4/TB3 10Gbe RJ45 adapter older black colour model with Marvell AQC107 chipset (new one with Marvell AQC113C chipset)
M1 Huawei ONT --> TP-Link Archer BE805 router --> 2.5Gbe/10Gbe mixed switch (one 10G RJ45 port, one 10G SFP+ port, quad 2.5Gbe RJ45 ports) --> Fibre Cable --> 10Gbe SFP+ 8-port switch + 10G SFP+ RJ45 adapter --> Acer Laptop with XikeStor 10Gbe adapter
Bash:
 ookla-speedtest-1.2.0-win64  .\speedtest.exe -s 7311
   Speedtest by Ookla
      Server: M1 Limited - Singapore (id: 7311)
         ISP: M1
Idle Latency:     2.08 ms   (jitter: 0.06ms, low: 1.98ms, high: 2.19ms)
    Download:  8212.24 Mbps (data used: 3.8 GB)
                  5.13 ms   (jitter: 0.46ms, low: 1.28ms, high: 6.69ms)
      Upload:  8005.23 Mbps (data used: 10.6 GB)
                  3.65 ms   (jitter: 0.44ms, low: 1.22ms, high: 7.49ms)
 Packet Loss: Not available.
  Result URL: https://www.speedtest.net/result/c/7a867e46-b0a1-4950-a4d0-dd511a79dabf
   Speedtest by Ookla
         ISP: M1
Idle Latency:     2.34 ms   (jitter: 0.12ms, low: 2.22ms, high: 2.44ms)
    Download:  8191.45 Mbps (data used: 7.6 GB)
                  4.41 ms   (jitter: 0.84ms, low: 1.44ms, high: 7.43ms)
      Upload:  7564.28 Mbps (data used: 9.6 GB)
                  3.59 ms   (jitter: 0.40ms, low: 1.11ms, high: 7.09ms)
  Result URL: https://www.speedtest.net/result/c/6e91b2ed-0860-4048-a2d1-0fb46e5b62ff
Test done yesterday using an low power Intel N100 Mini PC, with Intel 82599ES chipset based dual 10G SFP+ ports, running Proxmox VE 9.
So far I have not seen faster upload speed in this forum.
So far I can see M1 got the fastest upload speed of about 8.9Gbps. Download speed is pretty consistent at about 8.12Gbps.
I am actually using a pretty low end low power Mini PC and container with two virtual CPU.
I tested with different OOkla SpeedTest servers as well.
M1 10Gbps plan, TP-Link Archer BE805 router
Wired client: Intel Mini PC with Intel N100 CPU, 8GB RAM, 256GB SSD, Intel 82599ES dual 10G SFP+ ports.
Software: Debian 13 Linux LxC container on top of Proxmox VE 9.2.
Bash:
root@debian13ct14r1:~/ookla# ./speedtest -s 7311
   Speedtest by Ookla
         ISP: M1
Idle Latency:     1.91 ms   (jitter: 0.07ms, low: 1.83ms, high: 1.99ms)
    Download:  8120.51 Mbps (data used: 3.7 GB)
                  5.27 ms   (jitter: 0.34ms, low: 2.66ms, high: 8.17ms)
      Upload:  8900.06 Mbps (data used: 4.1 GB)
                  3.53 ms   (jitter: 0.51ms, low: 1.64ms, high: 4.50ms)
  Result URL: https://www.speedtest.net/result/c/e355584a-fffc-40d7-885b-7c35b48bf594
root@debian13ct14r1:~/ookla# ./speedtest -s 13623
   Speedtest by Ookla
         ISP: M1
Idle Latency:     3.69 ms   (jitter: 0.10ms, low: 3.58ms, high: 3.77ms)
    Download:  8138.38 Mbps (data used: 9.8 GB)
                  6.82 ms   (jitter: 0.33ms, low: 2.92ms, high: 9.39ms)
      Upload:  8896.94 Mbps (data used: 6.2 GB)
                  4.91 ms   (jitter: 4.43ms, low: 3.42ms, high: 215.75ms)
 Packet Loss:     0.0%
  Result URL: https://www.speedtest.net/result/c/2c05c3ad-29d3-40c7-a0bb-acb54098ed29
root@debian13ct14r1:~/ookla# ./speedtest -s 5935
   Speedtest by Ookla
      Server: MyRepublic Singapore - Singapore (id: 5935)
         ISP: M1
Idle Latency:     2.97 ms   (jitter: 0.19ms, low: 2.87ms, high: 3.20ms)
    Download:  8130.41 Mbps (data used: 4.1 GB)
                  6.19 ms   (jitter: 0.43ms, low: 2.94ms, high: 8.04ms)
      Upload:  8877.69 Mbps (data used: 6.2 GB)
                  4.43 ms   (jitter: 0.68ms, low: 2.43ms, high: 6.04ms)
 Packet Loss:     0.0%
  Result URL: https://www.speedtest.net/result/c/18fc44e9-dd67-45e1-ba99-eb24b75b3333
root@debian13ct14r1:~/ookla# ./speedtest -s 62020
   Speedtest by Ookla
      Server: Axclusive Pte Ltd - Singapore (id: 62020)
         ISP: M1
Idle Latency:     3.01 ms   (jitter: 0.11ms, low: 2.79ms, high: 3.13ms)
    Download:  8141.66 Mbps (data used: 3.9 GB)
                  6.18 ms   (jitter: 0.49ms, low: 2.51ms, high: 8.48ms)
      Upload:  8315.88 Mbps (data used: 4.2 GB)
                  4.71 ms   (jitter: 0.51ms, low: 2.58ms, high: 6.82ms)
 Packet Loss:     0.0%
  Result URL: https://www.speedtest.net/result/c/c5fa4c1e-e0d8-4d37-95ab-51ba89d7e26b
root@debian13ct14r1:~/ookla# ./speedtest -s 75893
   Speedtest by Ookla
      Server: WhizComms - Singapore (id: 75893)
         ISP: M1
Idle Latency:     3.69 ms   (jitter: 0.12ms, low: 3.63ms, high: 3.78ms)
    Download:  8138.47 Mbps (data used: 3.9 GB)
                  6.87 ms   (jitter: 0.51ms, low: 3.55ms, high: 11.75ms)
      Upload:  8759.86 Mbps (data used: 4.4 GB)
                  4.66 ms   (jitter: 0.66ms, low: 3.40ms, high: 6.76ms)
 Packet Loss:     0.0%
  Result URL: https://www.speedtest.net/result/c/98a0d46a-96ab-44bc-b1a8-784d485d3bb8
PVE Host itself is similar.
Bash:
root@pveminirouter1:~/ookla# ./speedtest -s 7311
   Speedtest by Ookla
         ISP: M1
Idle Latency:     1.94 ms   (jitter: 0.05ms, low: 1.87ms, high: 1.98ms)
    Download:  8146.05 Mbps (data used: 9.4 GB)
                  5.04 ms   (jitter: 0.34ms, low: 1.99ms, high: 6.07ms)
      Upload:  8909.53 Mbps (data used: 4.2 GB)
                  3.54 ms   (jitter: 0.48ms, low: 1.95ms, high: 4.86ms)
  Result URL: https://www.speedtest.net/result/c/35989741-6840-4600-9028-1ee643b9c8fd
root@pveminirouter1:~/ookla# ./speedtest -s 13623
   Speedtest by Ookla
         ISP: M1
Idle Latency:     3.52 ms   (jitter: 0.17ms, low: 3.06ms, high: 3.63ms)
    Download:  8134.30 Mbps (data used: 7.1 GB)
                  6.86 ms   (jitter: 0.40ms, low: 3.67ms, high: 9.97ms)
      Upload:  8887.74 Mbps (data used: 4.5 GB)
                  4.50 ms   (jitter: 0.54ms, low: 3.35ms, high: 5.92ms)
 Packet Loss:     0.0%
  Result URL: https://www.speedtest.net/result/c/c068d817-bdb4-405a-9340-cf0159401263
Best download speed from Jasonho at 8345Mbps.
VQ10G ---- > Alta Lab Route10 (SFP+) ----long cable---> Unifi 10G switch. ---> CalDigit 10Gb USB adapter ---> Monitormate USB hub --- TB4 USB cable ---> Macbook M4 Pro
Frankly speaking, I never get any chance to feel the 10G speed unless I speedtest. Most of the time, my family aggregated bandwidth wont be more than 1gb.
New speed 8345/7770
number 2 & 3 Sir…
Local online shops links for reference. I am not good at finding lobangs.
1. 5Gbe adapter is pretty cheap
Check out WAVLINK USB C to Ethernet Adapter 5Gbps, Driver-free RJ45 Gigabit Ethernet Network Adapter for Laptops, Computers and More, Grey Aluminum Case for Windows 10/11, Mac OS 11 or Later for $29.98. Get it on Shopee now! https://sg.shp.ee/BujR6KbC
(Very similar price to Taobao at RMB 149).
Check out Ubiquiti UACC-Adapter-RJ45-USBC-5GbE, 5G Ethernet Adapter for $89.00. Get it on Shopee now! https://sg.shp.ee/nS8qunG2
2. 10Gbe ones will be much more expensive
Check out Acasis 10 Gigabit Ethernet Adapter Compatible with Thunderbolt 4/3 USB4 40Gpbs USB4v2 80Gpbs at 53% off! $142.69 only. Get it on Shopee now! https://sg.shp.ee/rPBHmhtr
(This seems to be only a bit higher than Taobao pricing at RMB 600).
Check out Ubiquiti Unifi 10G Ethernet Adapter | UACC-Adapter-RJ45-USBC-10GE at 3% off! $265.90 only. Get it on Shopee now! https://sg.shp.ee/x4ghUTHj
3. There are cheaper 10Gbe adapters from Taobao: IOCrest, Xikestor, Orico, etc. They may be sold at local online platforms but I do not know if the shops are good or not.
I got three USB4/TB4/TB3 adapters from Taobao, IOcrest, GRiS and XikeStor (old version). All three are working okay.
Lazada pricing
1. WavLink 10G USB4/TB4 adapter at S$146
WAVLINK 10G Ethernet Adapter for Thunderbolt 3/4/5 & USB4, Supports 10G/5G/2.5G/1G/100M/10M Adaptive Speed, Compact Aluminum Design, Includes 40Gbps USB-C Cable, for Mac, Windows, Linux, ChromeOS | https://s.lazada.sg/s.6eNiZ?c=d&t=p-iFAlEFx-s2CKlUho
2. WavLink USB 5Gbe adapters at S$25 (WL-NWU341G)
WAVLINK USB C to Ethernet Adapter 5Gbps, Driver-free RJ45 Gigabit LAN Ethernet Network Adapter for Laptops, Computers and More, Thunderbolt 5/4/3 Compatible, for MacBook Pro/Air, iPad Pro, Dell XPS | https://s.lazada.sg/s.6eNle?c=d&t=p-i3ppvbc-sPJzfAG
3. WavLink USB 5Gbe adapters S$32 (WL-NWU341GD) with 95W charging port.
WAVLINK USB C to Ethernet Adapter with 95W Charging Port, Driver-free RJ45 Ethernet Adapter 5Gbps for Laptops, Computers and More, Aluminum Case for Windows 10/11, Mac OS 11 or Later, Linux and More | https://s.lazada.sg/s.6eNMj?c=d&t=p-i3o4Sk9-sPB5BRE
