$850.00 gaming rig
mini_cow
i will using intel 6500k all board are DDR4
dont you need a Z170 to overclock instead of H170?
edit: is it wise to get your friend an OC chip when he doesnt even know how to build his own rig?
edit 2: i know you get best bang for bucks by overclocking. im not sure what gains you have for autocad but the result in games is frankly negligible. also there is no such thing as a free lunch in the world. you need to spend more on fans, ventilation and your chip/board will likely die faster. end result...your friend might have to spend more in the near future...
MianBaoFren
johnny chai
guys!!
which board do u think suitable for the noob like my friend whom dont know about OC ?
MianBaoFren
mini_cow
may i know how do i check on the Z or H or B series..
i kind of noob selecting mobo
i'm not an expert and im lazy to research, but iirc the difference between these mobos are very small. a usb c convertible here. an overclock there. since u already know what u want, just tell the person what you need. and pick the cheapest loh. also, make sure your case can fit it. ie make sure you dont buy an atx board when your case supports a micro-atx one?
even if your mobo gets destroyed in future, you still need to go back to the distributor to RMA it
MianBaoFren
mini_cow
http://www.tomshardware.com/reviews/motherboard-buying-guide,4596.html
Read this. It helps alot. But it might be easier if u list down what u actually need.
(E.g. more sata ports, onboard hdmi, onboard wifi) and find one that suits your needs.
And of course, your form factor.
Sent from A Cat Who Does Not Need A Reason To Post using GAGT
You all hardcore stuff. I'm like walk into a shop. Tell uncle I want to play this game that game and what I do. Then my budget. Then ask him can or not hahaha Luckily for me so far still can
MianBaoFren
mini_cow
Or ts could just do that. I think mobo is not a problem. How to squeeze everything out is the problem.
i dont think what he needs is rocket science tbh. 3 HDD means need 3 SATA most mobos should be able to do this. HDMI output from mobo should be standard fare these days too.
Only tricky ones are when you wana OC or when you need the USB C reversible. And yes maybe the wifi thing. But a wifi dongle costs like what...$40 or less? Also there is probably the number of USB 3 ports etc but frankly....alot of devices still work on USB 2...
TS is also not into "future proofing" so his budget should be able to work. I'd say maybe buy the 1060 online or get a second hand 980. They should be really cheap now no?
MianBaoFren
With his budget, he can only get a 1060 3gb tops if he wants that i5 which is needed for AutoCAD? I build a similar PC recently and it cost me up to 1.05k.
ZrE0_Cha0s
Wow, just half of the day, now it seems like TS himself want a new PC den his friends. And all these changes end up will be above budget...so what's the budget now?
johnny chai
My friend needed a pc,so I help him build.
Should be $900+
If can be done
