InvincibleTofu
- Mar 29, 2005
Yep.Are you on the latest BIOS?
But technically F5 is only a GUI update over F4
It's been the platform spec for awhile, nothing has changed.
https://forums.hardwarezone.com.sg/117187385-post130.html
But most youtubers are not understanding how the platform works and create more misinformation.
But always good that someone goes out there to clear the misconception.
I am sure the chip will face degradation really quickly if the temps are really high.
Doubt it. TjMax for all these CPUs are 100 degrees.
It is high voltage and spikes that kills/degrades the CPU not high temps.
Besides, these high temps are only on AVX stress testing. During gaming, it does not cross 65 degrees. Unless you are day in day out stress testing and running the CPU at very high voltage and high LLC's, there is nothing to worry. If anything, your PSU and Board will give way first before the CPU.
, it's just a general statement.Doubt it. TjMax for all these CPUs are 100 degrees.
The 8C is actually spec'd at 193A IccMax. Of course the datasheet assumes full vdroop (absence of llc).
With the datasheet operating ranges (and mb vendor recommendation) you can have a good risk assessment for OC. But with the datasheet numbers there's a good chance you can turn it into a 200W TDP CPU while maintaining long term reliability (also well within Raja@asus recommendation).
Notable quotes from Raja@asus (ex AnandTech sr/mb editor here.
https://edgeup.asus.com/2016/get-be...ell-e-processors-asus-thermal-control-tool/6/![]()
It's still overall a good measure to set your own custom long & short duration power limits/tdp to suit your rig's cooling capability within the oc tdp guideline rather than leaving it at the 4killowatts max (aka unlimited) you can set within this platform's inbuilt safety limiters.
I got Gigabyte because Asus boards apparently install a lot of bloatware in the Z390 generation
https://www.techpowerup.com/248827/...-push-software-into-your-windows-installationHuh? What do you mean Bloat?
Gigabyte boards are very good and reliable but for overclocking prowess and advancement, you can't beat Asus. Even their bios layout is far neater. Like I mentioned I only got Gigabyte again cause I had superb experience with my 6700K and Z170 from Gigabyte. I only sold it off this year since 2015 and it was very overclocked on that one.
)Can agree on ATX front giga did well with hardware (even given a pass by hlots guru)
Personally I moved from the Asus M8I to Gaming-ITX/ac before the large cost cutting on hardware came.
No regrets at all, after what they did to the ITX line refreshes (only pro gaming aka strix).
From true 6+2 phase IR3553s + 10K Nichicon caps -> Strix z270i/Z370i 6+2 inefficient and budget 6+2 onsemi + 5K Apaq taiwanese caps -> currently Z390I 3+2 phase fake double using budget onsemi + 5k apaq.
(Z390I Source Elmor - former Asus ROG R&D Hardware till a few days ago) https://www.overclock.net/forum/27701810-post2968.html
Totally not impressed, they're trending towards what elmor is describing here.
https://www.reddit.com/r/hardware/comments/6atydw/open_but_personal_letter_to_the_pc_components/
Far better boot times, 60A intersil sps. Haven't seen idle time instability (certain uefi revisions on M8I I've seen that..) as well even quite heavily overclocked and I don't off my PC. Don't regret making the switch at all.
Yep.Waoh. Like Windows 10 need any more help with bloat hahahaha..
