Advice: AIO PC Builds.. possible?
xxduckxx
Some background info
1) wife wants to buy iMac cause its aesthetically better looking vs. a desktop
2) i did some googling and realized that Intel actually has a chasis that lets you build your own AIO (all-in-one) PC.. Thin Mini-ITX-Based All-In-One PCs
3) managed to convince her on an AIO instead vs. paying the sky high for an Imac 27inch..
so my question is any bros here know if Sim Lim shops have the capability to build AIO pcs? and maybe to recommend which shops would be best and even recommend me a build?
budget is around 1-1.5k (agar for now)
thanks in advance for the advice
fleas1
mynextcom has a DIY mini itx ivy bridge build you can do. (comes with 3 years warranty). Everything assembled and I think there's free delivery.
you choose your casing first then you can choose your hardware options. You will need to buy your monitor separately and if you need keyboard and stuff.
Ivy bridge would be a cheaper option to Haswell(latest intel generation)
note: the DIY build option do not come with graphic card installation.
xxduckxx
thanks bros for the advice.. and many thanks to bro fleas for the link .. will check it out :) alittle sad that you said no GPU though ):
fleas1
nope, means u have to add manually to the ITX build.
its still possible to do so as most ITX have space for a normal sized card.
Go for coolermaster elite 120 advanced. good space and considered good air flow for an ITX
Knight_Rider
Still looking for reviews. :(
Lippyt
Vesa Mountable Aluminium case - $100
Order from this bro: http://forums.hardwarezone.com.sg/c...s-audio-cards-psus-lian-li-cases-3875895.html
Asus H87i-Plus + Core i5 4430 - $411
2 X G Skill 1600Mhz 4GB - $100
WD Blue 1TB - $85
Dell 27" U2713M - $779
Total: $1475
You may have to install additional fans. Best to ask case seller.
If you don't mind ordering from amazon + ship over yourself: Amazon.com: Antec Mini-ITX Case ISK110-VESA: Computers & Accessories
Also, have you considered a 21" iMac or a refurbished unit?
pa9797
You cannot built AIO yourself. You need to buy from brands such as Asus or HP or Dell.
Those intro by various bros are DIY rigs
NVDefender
Actually you can, depends on how you define AIO. Can use the VESA mount Antec ISK 110, mount it on your monitor and you'll get something very similar to branded AIO.
devilwahaha
Many if not most "branded" AIO's now do come with at least some sort of decent discrete graphics, while using the ISK 110 you will almost definitely be stuck with onboard graphics, which would seem very silly if in this case we are comparing against a 27" iMac.
NVDefender
Well of course, can't win all can you? I'd say AMD's APU's graphics is decent enough but the APUs will probably push the ISK 110 power brick to breaking point. Hopefully next gen APU will improve on power efficient so we'll have more choices on DIY AIO.
Ark Law
Short Answer: No
Long Answer: Can, but it isn't going to be as sleek, slim or stylish as an iMac. And don't expect astronomical savings over a Mac since doing a DIY for this kind of build already require a significant premium to pay for
xxduckxx
wow lively discussion.. yeah i was reading on the itx mini cases and yes it might not end up as sleek as the AIOs from the brands or vs. the imac for that matter.. sigh back to the drawing board..
fleas1
those really small ones like apple mini or like gigabyte mini computers(as small as a powerbank) I believe do not have dedicated graphic cards. which means they are using intel's HD graphics.
So it depends on what you need it for. If its gonna use for gaming or rendering then you probably be better off with ITX. Go for those mini PCs if you are just doing casual usage eg: surfing, documents(excel, word, powerpoint...etc), youtube...etc.
good luck!
pa9797
This option not good as the case is restricted on discrete graphics. If we define AIO as everything is in one monitor
saysuzu
aiyo, your wife hard to please sia
just get mac mini for her sua
devilwahaha
He also never say wife complain our suggestions lousy, just that he's yet to find something visually pleasing yet at least close in performance to the iMac while not costing a bomb.
To TS, I think the Asus AIO's would be a good bet. Decent discrete graphics + not bad screen panel + pretty large HDD.
