Advice for Water Cooling Setup
zedane
Looking good there. Pretty decent temps. Didnt know i7-860 runs that cool. Did you overclock your chip?
godot09
Nope. The CPU for this rig is I7-950 so the temps are very good compared to when it was air-cooled. When it is air-cooled, at ambient 31 deg, the cpu temp is around 43-45 deg at idle. And, I did not overclock the cpu.
The I7-860, is certainly a much cooler cpu compared to the i7-950. At idle, it hovers around 33-35 deg, air cooled. There is no need to water cool this unit.
Coming back to the I7-950 ... At idle, the temps improve alot but the real potential of WC is seen under load.
zedane
ah my bad didnt see the i7-950 stated. Watercool shines mostly at load. Idle wise would even lose to better air cooler.
KB
i'm thinking of water too, also looking the the xspc kits, 240 or above. thing is i'm thinking if i need to change out my cpu, can i just remove the block and replace or do i have to drain the system?
or might just take up a corsair for simplicity. my cm V6 is not up to par when i do linx with AVX le...
Mythmaker
Depending on how long your tubes are. If like godot09 then sure no problem. If something like mine:
Then probably have to drain the entire loop :s22:
Don't bother with stuff like Corsair H50 or H60. There won't be much of an improvement over your current v6.
KB
my V6 is giving me 83C full load IBT w/latest linpack AVX. cmi leh. this is if i do 4.8ghz with my 2500k. now i only dare to hoot 4.5ghz. still giving me around 70+ degC.
godot09
My GPU waterblock arrived on Sunday. Got it up and running. The temperature findings are:
Stock fan:
idle : 54 deg
load : 80 deg
With WC:
idle : 44 deg
load : 50 deg
The drop in temperature is substantial. What is more impressive is the load temperature. The max was about 50 deg with the average temperature hovering around 45+ deg during gaming. No longer do I need to bear with the loud fan noise during gaming.
BTW, the fan blowing directly at the NB significantly reduces the temperature from 66 deg to 44 deg. Since I kept the backplate of the GPU on, it acts as a firm base for the fan.
Aeroplane.
http://wehub.com/hwz/wc_2.jpg[IMG]
Stock fan:
idle : 54 deg
load : 80 deg
With WC:
idle : 44 deg
load : 50 deg
BTW, the fan blowing directly at the NB significantly reduces the temperature from 66 deg to 44 deg. Since I kept the backplate of the GPU on, it acts as a firm base for the fan.[/QUOTE]
Those are ACRyan fans i suppsoe? Damn nostalgia, ****ing noisy though.
godot09
I7 950 / X58 Sabertooth
AMD 6950 2GB
With the completion of the GPU loop, the WC-rig is finally done. Will stop tinkering with it and start enjoying what it can offer.
Perhaps, just perhaps, I might waterblock another 6950 2GB in the near future if necessary.
For now, this water-cooled single 6950 2GB handles eyefinity just fine.
zedane
AMD 6950 2GB
With the completion of the GPU loop, the WC-rig is finally done. Will stop tikering with it and start enjoying what it can offer.
Nice:D Enjoy your rig man.
ravener
nice, considering to either get a new casing or change to watercooling...
looks like watercooling might be a good choice...
edit: as ghillie has pointed out, do list out the cost of your watercooled setup.
godot09
It goes to around 50+ sometimes but by and large hovers around 45 -50 thereabout. Looks pretty ordinary on idle it seems but a huge difference when on load.
godot09
wow nice wats the total dmg on ur wc?
1 x XSPC Rasa 750 RX360 WaterCooling Kit
1 x PT Nuke
1 x Lamptron Fan Controller FC4 Black (FC4)
1 x EK FC6970 - Nickel + Plexi
1 x UV CCFL
Tubing + extra fittings
An estimate would be around $550
