myth_shenhua
- Sep 16, 2006
No idea whether the UDM Pro can do dual WAN properly or not, and I'm not too keen to look through their community forums to find out whether it actually does support dual WAN properly. If I'm you I'd rather use the AX88U for routing.
One thing about Ubiquiti is don't trust their marketing materials when they promise to add the feature somewhere in the future via a firmware upgrade. They have reneged on marketing promises enough times that no one should trust their marketing materials unless said features are already baking into the firmware.
I'll gravitate more towards option 2.
Anyway I thought you said your contractor will test for dead spots? I presume they will fix any dead spots they found after installation (probably by instaling more access points) since there's really no point testing if they are not going to bother to fix it.![]()
thank you
